Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-23-2016, 01:25 AM   #1
BigDan3131
BigDan3131's Avatar
Question Leaf Spring Sliders
I know most of the trucks are either the stock arm style or a race type suspension but I have a lwb GMC with leafs. I was planning to remove all but the main leaf and maybe one more. Then add the sliders and if I need to some other form of traction device sort of like the traction bars for the 55-57 trucks. Do any of you use the sliders on your trucks or other leaf sprung vehicles?
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 08-23-2016, 11:31 AM   #2
Super73
Super73's Avatar
Re: Leaf Spring Sliders
A buddy of mine has an S10 in which we did sliders, mono-leaf and a slidalink set up. It probably makes a honest 450rwhp on the N20 and dead hooks on marginal surfaces.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 08-23-2016, 09:52 PM   #3
hotrod 80
mini truck racer
hotrod 80's Avatar
I have the same set up. All Calvert . Split mono , 9 ways and caltracs with roller bearing sliders . My 60' times vary in the thousandths . I get made when there is a delay on a hot track cause I can get down anything and the radial slick guys cant . I'll have to dig for a picture .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 08-26-2016, 05:08 PM   #4
BigDan3131
BigDan3131's Avatar
From the way it looks on my truck I would have to mount it flush with the top of my frame rail to get the height I want then gusset it. If I need to lower further I can R&R the front perch as well. There was a video on youtube showing how they work, perfectly...
Old 11-19-2016, 11:24 AM   #5
hotrod 80
mini truck racer
hotrod 80's Avatar
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 11-20-2016, 03:18 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
https://www.youtube.com/watch?v=Zi0HZSnNhKI
The only video I found. The other ones are off road and trucks...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
