Old 08-27-2016, 06:58 PM   #1
wbrenk
washer pump problems
I have an 85 c20 and the washer pump isnt working. I took it out and hooked it up to 12v battery and it runs fine. I checked the fuses and they are all good so i hooked up a multimeter to the connecter where the pump was plugged in and im getting 12v there. So im confused why the motor isnt working. Any ideas?
wbrenk is offline   Reply With Quote
Old 08-28-2016, 09:54 PM   #2
Dave in Ozark
Re: washer pump problems
Check wiring diagram- the switch may be intended to switch negative? Shot in the dark
Dave in Ozark is offline   Reply With Quote
electrical issue, washer pump
