Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 09-08-2016, 01:09 AM   #1
My65's
'65 burb radiator frame mounts
Ok, so I'm getting close to being ready to get my frame to powder but I don't want to cut off the front vulcanized radiator support mounts without knowing what direction to go when I'm done. Any suggestions? Can I get replacements? Are their rigid bolt on options? Do I just have to be careful and reuse what I have??? Any help, pictures, links would be a big help.
My65's is offline   Reply With Quote
Old 09-08-2016, 02:22 AM   #2
padresag
Re: '65 burb radiator frame mounts
they are used only on panels and suburbans. due to the longer body structure of the suburbans and panels those are there to give some flex to the system. p/u body you just have 2 cab mounts per side and the rad mount. panels and suburbans have 5 a side plus the rad mount. the rad support mounts on a pu do not have that vulcanized rubber insulator, but are solid. as long as the rubber is not to badly cracked they should be ok. you may have to use shims in there as they may be sagged a little.
one may be able to sweet talk steele rubber into a new set???????????. never hurts to ask. the worst thing they can say is no to you.
ron
padresag is offline   Reply With Quote
Old 09-08-2016, 07:52 PM   #3
66 Burban
66 Burban's Avatar
I had bad luck with mine --- powder coating temp (400 deg),
Vulcanizing turned loose and they separated. I suggest cut rivets out, remove and re-install after powder coating with grade 8 bolts. I'm installing another set on mine in this manner...
Remember: "When seconds count, the Police are only minutes away".
Thx,
Billy B.
66 Burban is offline   Reply With Quote
Old 09-09-2016, 09:13 PM   #4
My65's
Awesome, thanks guys. I will cut them off, refinish, and hope all works out!
Old 09-11-2016, 09:39 AM   #5
ironman3452
ironman3452's Avatar
take picture of mounts, then cut off, replace when done
ironman3452 is offline   Reply With Quote
Old 09-11-2016, 11:26 AM   #6
padresag
I do not know why one would have to take pictures of them as it would be hard to put them on upside down or backwards
ron
Old 09-11-2016, 06:55 PM   #7
My65's
Lol...pictures never hurt but yup, cut off, clean, derust and paint!
