Old 09-08-2016, 02:17 PM   #1
KyleSeal
KyleSeal's Avatar
Finding a Good Engine Ground
As the title states.. need to find a good engine ground.. hooking up a MSD 6AL w/ rev limiter box, and the harness says it needs a ground coming from the middle of three prongs on the distributor going to a 'engine ground'. Whats a good place for this?
I have a Edelbrock Performer RPM intake (aluminum), and a Holley 750 on top of it.
Would a carb stud be okay? I was told aluminum doesnt ground well. I was also thinking putting it on the alternator bracket. Would a bracket work?
1984 K30 454. Stock HEI, plus the mentioned box.
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 09-08-2016, 02:26 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Finding a Good Engine Ground
With the two choices you mentioned I would go with alternator bracket..make sure to clean any paint/grease off of it..any bolt going into the engine block would work as well..make sure you have a good ground from engine to frame and body..your battery to engine ground would be a good place but would mean a longer wire..
Old 09-08-2016, 03:18 PM   #3
Dead Parrot
One traditional ground is the engine to firewall cable that runs from the passenger side valve cover bolt to the firewall. They often disappear during engine work so make sure you have one regardless of where you decide to ground your gizmo.
If the Performer series still includes the threaded holes for the coil bracket, you could use one of those. Use a stud and two nuts instead of a simple screw.
Dead Parrot is offline   Reply With Quote
Old 09-08-2016, 05:45 PM   #4
KyleSeal
KyleSeal's Avatar
Thank you all for the help. I decided to run it to the alternator bracket, as I have RTV on my valve cover bolts, so I didn't want to take my chances.
Old 09-08-2016, 06:43 PM   #5
Jaysonb
Jaysonb's Avatar
I use the accessory bolt holes on the back of the head, firewall side. They are 3/8 bolt holes.
Jaysonb is offline   Reply With Quote
Old 09-09-2016, 02:29 AM   #6
hatzie
Moderator
hatzie's Avatar
That's where the cab to engine ground strap should go as well. Not to the valve cover bolt.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
6al, electrical, ground, msd, pickup
