Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 09-11-2016, 08:10 PM   #1
60burb4me
new bed 1960 burb
Can anyone explain how the bed goes back into a suburban I built it and want to test fit it. trying to find out the best way to do it. also looking for the rubber that goes on top of the wood? or a suggested replacement?
60burb4me is offline   Reply With Quote
Old 09-11-2016, 08:50 PM   #2
padresag
Re: new bed 1960 burb
believe that it goes up from the bottom. there is a 3/4" 1/2 lap joint in the centre
ron
padresag is offline   Reply With Quote
Old 09-11-2016, 09:05 PM   #3
60burb4me
I took it out, in 2 pieces and built the replacement, but the way I see it it should go back in as 1 piece? it has to be covered with a rubber mat that is glued to the wood? has anyone done one?
Old 09-12-2016, 11:42 AM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
GM specifically made it two pieces and they go in from the top. You cannot put one in as one piece, unless you have the body off and all the crossmembers out and I am not even sure that works. Two pieces will allow you to slide each one under the body lip around the inside edge.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-12-2016, 08:56 PM   #5
60burb4me
So they put both pieces in, put them together, then bolted the bottom rails on, glued the rubber mat to the top, then bolted it to the body? man that seems like a lot of work on an assembly line? I took it out that way. but know I have the body on a cart for the body work and was hoping it slipped inform the bottom I am still going to give it a shot. I was just hoping someone already had a secret they could share.lol
Old 09-13-2016, 03:49 AM   #6
argonaut
argonaut's Avatar
If you have the body off then I would think that you could bolt the wood the the cross sills and then set the body back on top.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 09-13-2016, 11:13 PM   #7
60burb4me
that's what I am hoping, but I was hoping to find someone that has already done it.
Old 09-14-2016, 07:54 AM   #8
VictoriaHardware
VictoriaHardware's Avatar
I have done it. Take the assembled floor (wood & crossmembers) and load it in from the bottom. The front edge goes up in there first. Then raise the rear. Of course this assumes the body is off the frame.
VictoriaHardware is offline   Reply With Quote
Old 09-14-2016, 09:25 AM   #9
bpmcgee
bpmcgee's Avatar
Victoria,
What did you do for rubber bed mat? Were you able to find a reasonable replacement?
bpmcgee is offline   Reply With Quote
Old 09-14-2016, 07:33 PM   #10
60burb4me
no I have not found anything yet
Old 09-14-2016, 07:36 PM   #11
60burb4me
thanks Victoria I will give it a shot sunday.
Old 09-16-2016, 12:59 PM   #12
VictoriaHardware
I found some rubber-type that was the right thickness and came wide enough to cover the whole width of the floor. It had a similar pattern as the original, but was not exact. I don't remember where my notes are and I sold that truck before putting the rubber mat in so I can't report how well it may have worked.
