Old 10-07-2003, 04:23 PM   #1
gcolby
Dash lights
I have a 1972 Blazer, and I cannot get the dash lights to work for the life of me. I have checked most of the usual suspects, but nothing..... I bought it this way, and I am tired of driving with a flash light
Any ideas???
gcolby is offline   Reply With Quote
Old 10-07-2003, 04:47 PM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
You checked the fuse right? There should be a gray wire coming into the back of the dash cluster, in the harness. This is the incoming power for dash lights. Are the bulbs good? Is the black wire on the harness grounded well? Any of these things could affect it working or not. Also the intensity goes thru your headlight switch. I'd check the ground first though, then the fuse, and bulbs next. Good luck, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 10-08-2003, 12:27 AM   #3
gcolby
I thought I checked all that stuff, will recheck. I have yet to check the switch will try that...
Thanks for the reply
Old 10-09-2003, 03:16 PM   #4
pound41
Check the printed circuit for tears
pound41 is offline   Reply With Quote
Old 10-10-2003, 08:42 AM   #5
VTKidder
Use a test light and start chasing it right from the fuse box. Sucks, I know, but it'll find the issue. Check grounds too.
VTKidder is offline   Reply With Quote
Old 10-10-2003, 10:57 AM   #6
3wbdriver
3wbdriver's Avatar
While we're on the subject. My dash lights come on in the parking light position, but go out when I turn on the headlights. Sometimes, if I hit just the right spot on the rheostat, they'll come on, but the next bump in the road will douse them again. ??????
'72 Blazer, 4WD, 350/4 spd. Affectionately known as "Da Beast"
'04 Silverado (new daily driver)
'00 Intrepid (wife's ride)
It's a BLAZER dude! No options, no emblems, no a/c, no fancy shmancy. It's a BLAZER....
3wbdriver is offline   Reply With Quote
Old 10-10-2003, 11:26 AM   #7
red71cheyenne
Back in the sticks
Your headlight switch rheostat is shot. Buy a new switch. They are about $15. Jeff.
Old 10-14-2003, 03:34 PM   #8
gcolby
replaced switch.
fixed the problem
Thanks for the help
