10-03-2016, 12:57 PM | #1 |
47-53 Chevy 216 Engine Parts
Parting out a 216 Chevy Engine
Will try to post better photos . Paypal , Postal M.O. Or Check (allow clearance time before ship. I will combine shipping as long as parts will fit in same box. Air Cleaner $40 Carb ( will need kit ) $40 Fan $20 Crankcase breather tube $35 Distributor $20 Starter Linkage $20 Valve Cover $15 Thermostat Housing $20 3 speed Shift Rods $50 Oil Pan $75 Flywheel Inspection Cover and front plate if good $40 Intake manifold $50 Exhaust $75 Side Cover $15 Bellhousing $75 Flywheel $50 |
10-05-2016, 11:02 PM | #2 |
Re: 47-53 Chevy 216 Engine Parts
Last Chance . Going to the crusher on 10/8/2016
10-18-2016, 12:39 AM | #3 |
You should have some fun with it before you do that Paul.
https://www.youtube.com/watch?v=v0thsG1v6w8 |
10-18-2016, 10:37 AM | #4 |
Hey , good to hear from you . Cannot believe an old babbet beater can run that long at WOT let alone with no coolant. Appears the old 216 has more entertainment than parts value.
10-18-2016, 05:44 PM | #5 |
iis the v cover a script?
if so ill take it
1967custom |
10-18-2016, 06:20 PM | #6 |
Sorry it went to the crusher about a week ago. Thanks for the inquiry.
