Old 10-05-2016, 10:09 PM   #1
Mikem_72
Calling all airride guys!!! I need some advice
Hey guys I recently bagged my '70 stepper and I love the ride, stance and everything else that comes with bagging a truck ... but I ran into a problem. I just noticed that my front bags are sitting on the LCA's at ride height. Any advice on how I can fix this other than tubular lower control arms or cupping the ones I have? I did a lot of research before I bagged the truck and didn't think I would run into this issue so any help is appreciated. Thanks in advance.
Specs:
Front:
5 lug disc upfront
2.5" DJM spindles
stock Lower and Upper Control arms
upper bag plate and 2" cup on bags
removed bump stops
Dominator 2600
15" steel wheels 225/70 tires all the way around
Rear:
5 lug drum
1.5" lowering block
Shock relocators
CPP Adjustable trac bar (Bent)
CPP bolt in C Notch
Dominator 2500 bolted directly to the frame and trailing arm
-Mike
1970 C10 Stepside 350/700r4
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632707
Mikem_72 is offline   Reply With Quote
Old 10-05-2016, 11:32 PM   #2
tinydb84
tinydb84's Avatar
Re: Calling all airride guys!!! I need some advice
Truck looks great.
Clearance the arm with a torch and BFH.
David
Instagram: myfabguy
Old 10-06-2016, 12:27 AM   #3
bbbc10
Diggin The SquareLife
Aftermarket or cupped thats it
bbbc10 is offline   Reply With Quote
Old 10-06-2016, 01:28 AM   #4
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
You may be able to switch bags as well, diameter changes between different lift sizes. Can you stuff your rear 2500 series bags up front just to see how it fits?
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress
Ghostwhite is offline   Reply With Quote
Old 10-06-2016, 08:47 AM   #5
Mikem_72
Originally Posted by tinydb84 View Post
Truck looks great.
Thanks, yeah I could do that
I'm leaning towards the cupped ... if I cupped them would I just mount the bag directly to the LCA or would I just drop it in with the attached cup like it is now?
Yeah I thought about doing that and Ill probably try it this weekend. I need to play around with it a little more as far as ride height goes, I'm sure I can raise it a little more and get the clearance but I would still be paranoid.
-Mike
Old 10-06-2016, 12:58 PM   #6
tinydb84
tinydb84's Avatar
They mount straight to the arm. Here is a pic of my arms. You can see the mounting holes on the bottom.
David
Instagram: myfabguy
Old 11-10-2016, 08:31 PM   #7
rincones
rincones's Avatar
Nice progress Mike
Rincon
rincones is offline   Reply With Quote
