10-18-2016, 02:57 PM | #1 |
70 c10 5.3 fuel tank/pump advice.
Hi guys I am new to the forums i just picked up a 70 c10 step side short bed. I am going to be dropping in either a 5.3 or 6.0 and i was wondering what fuel tank and pump setup I should use. Ii am trying to do this swap on a budget also I want to run a rear mounted tank. I have been looking on the forums and I know there are a lot of threads on this subject but so many people run different setups. I was looking at some of the after market efi tanks but they are pretty expensive. i was thinking about runing this tank setup ( http://www.fueltankparts.com/67-72-e...-bed-fill.html )but its almost 900 hundred bucks and thats not really in my budget.
10-18-2016, 03:16 PM | #2 |
Re: 70 c10 5.3 fuel tank/pump advice.
I looked at several myself and ended up going with a Boyd Welding tank. They are pricey but they are well thought out and made.
10-18-2016, 04:31 PM | #3 | |
Still Learning
I ended up using a Blazer tank. HERE I also used a Walbro inline fuel pump. I've been really happy with the setup so far. I can't say this is the best setup, it is budget friendly and very reliable. |
10-20-2016, 07:02 AM | #4 |
10-20-2016, 10:51 AM | #5 |
If you can find an old Blazer or Jimmy those tanks will work as they were made to fit the same frame. LMC has rear mount tanks for like $150, sending unit for $50. I was gonna try it but ended up just replacing the behind the seat tank.
10-20-2016, 12:11 PM | #6 |
Get a Blazer tank[or Jimmy] 87-91 and a Delco EP 381. It will drop in place of the TBI pump and provide the pressure that the 5.3 needs. That will be the dollar down way to go. And what is better than using GM stuff on our trucks?
10-20-2016, 12:35 PM | #7 | |
Its a Truck Thing......
Did you have to mod the filler neck on the tank at all? Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
10-20-2016, 01:10 PM | #8 |
i picked up a new 1990 wrangler tank for 85.00 and a new 1987 blazer 25 gallon sender that fits right in. works great
1967custom |
10-21-2016, 09:15 PM | #9 |
I used a boyd tank for my LS swap. I couldn't be happier with the choice. I realize it's expensive, but it is well worth the $$$.
10-21-2016, 09:35 PM | #10 |
You have to come up with some type of filler. Some people just put it right in the floor of the truck witch would be a last resort for me some make a filler to go behind the tail light like 57 Chevy style. Also some do a filler behind the marker lamp while others graft in a filler door in the bedside. There are lots of options there to work out.
Other options for a tank is a Camaro tank or Chevelle tank that filler takes a fold down plate and puts the filler behind the bumper. I think that may be the cleanest I have seen |
10-22-2016, 06:33 PM | #11 |
I used a 65 gto tank with the filler behind flip down tag. Works OK.
I item I have noticed though - with 'middle fillers' almost gone - you have to get close to the pump in most stations for the hose to reach. |
