Old 10-22-2016, 11:55 AM   #1
ck5566
Help an Old Man Out
WIRING DIAGRAM PLEASE.
I dont know if this is the place or not for this but here goes. My be some one here has connected this unit, I hope. This FM/AM Cassette Car Stereo was given to me by one of my daughters a while ago with only the "Operating Instructions" booklet (publishing date of 1998) witch is helpful but DOESNT have a Wiring Diagram in the booklet or on the radio it self. I'll post some pictures to see if any body can help me with my wiring problem, might take two post. Thanks in advance.
PS, It was in working condition when given to me should work again its just been resting for a while. LOL LOL
ck5566 is offline   Reply With Quote
Old 10-22-2016, 12:02 PM   #2
ck5566
Re: Help an Old Man Out
Round Two
Old 10-22-2016, 12:26 PM   #3
michael bustamante
michael bustamante's Avatar
yellow to batt positive
red to ign. positive. black to ground.
2 blues are not used unless you have an extternal amp or a power antenna.
purple and green wires are for the rear speakers. black stripe is negative most likely
white and greys are for the front speakers
1967custom
michael bustamante is offline   Reply With Quote
Old 10-22-2016, 12:56 PM   #4
roboticjunky
Here's a diagram from another forum for a xr-c5100r (probably the same as your headunit)
roboticjunky is offline   Reply With Quote
Old 10-22-2016, 12:59 PM   #5
ck5566
Yah I also thought that is how its wired. Here is what I found online a while back (if you can believe what you find online now days) pretty much what you have suggested. Its not working when it is hooked up that way. Got to be some thing I am not doing before or after hooking it up You Think?
Old 10-22-2016, 01:07 PM   #6
ck5566
Wrong unit, you show XR-C5100R unit and also the wire connector is wrong mine has only one plug & along with the location of the Fuse is wrong. Apples for apples guy. Mine is a XR-C5100 not with a R on the end. thanks anyway
Old 10-22-2016, 06:00 PM   #7
ck5566
Free Bump TTT
Old 10-22-2016, 06:10 PM   #8
davepl
davepl's Avatar
Here you go. Going to be tough to read in the forum reduced size, but I found it online.
Light Blue -> Antenna
Red -> Switched power
Yellow -> Unswitched (battery) power
Black -> Ground
White/grey/green/purple -> Speakers
You have ext antenna (likely unused unless you have a power antenna) and ext amp (unused unless you have an external amp you need to turn on).
If you don't have ACC, hook the red to IGN.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-22-2016, 06:21 PM   #9
davepl
davepl's Avatar
Here's another view. I'll also try to attach the PDF, don't know if I can.
Old 10-22-2016, 07:06 PM   #10
ck5566
That one is similar to what I posted before as for witch wires go to what,yellow/red/black & all speaker wires. YOU must have a better GOOGLE search then I have.LOL Thanks
Old 10-23-2016, 02:24 AM   #11
719foot
The thing i noticed first, is that there is no fuse installed in the slot underneath the multi pin plug. I would try that. Diagram says 10A. If it has been sitting, I'd be prepared for the electrolytic (polarized, can shaped) capacitors to be dried out, they may pop in short order, but are easy to replace.
719foot is offline   Reply With Quote
Old 10-23-2016, 06:16 AM   #12
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I'm in the process of hooking up a Custom Autosound USA-1 AM/FM/Cassette in one of my 72's. The instructions were adamant in stressing the importance of correct speaker polarity or the unit would not work. Well, I did cross one set and sure enough when I went to turn it on, I had power but no sound. After rechecking the polarity on all eight speaker wires, I had in fact got the wires crossed. Plays like a dream now but has more button functions than my brain can process and retain. My RAM (random access memory) is dwindling as the years pass and megabytes become minibytes.This radio came with an inline fuse for the battery power and it also has an inline noise filter. The instructions indicate what filters you may need if you have a noise problem, where to get them, and how to determine what the origin of the noise is weather it be an alternator or running your
low level RCA cords to close to the power source. If your running an amp, run the supply power to the amp on one side of the vehicle and run your speaker wires down the opposite side of the vehicle to minimize noise caused by power fields.
Forgot to mention this...It looks like your radio has a screw boss located in the center of the back of the radio. Most radios, mine included come with a small mounting bracket that serves two very important needs. One is to support the back of the radio and it also provides the ground for the radio itself. A couple of small self drilling teck screws and a 4" piece of plumbers tape works very good. If for some reason you decide to only run two speakers, be sure to cap the ends of the speaker wires not being used. Do not try to incorporate the fronts with the rears because internal damage may result, use the fader option to play the two speakers you chose to full stereo capacity. Good luck
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 10-23-2016, 07:30 AM   #13
ck5566
I know the fuse is out, that's not the problem here. The radio has been wrapped up in a towel for the last 10 years now. I have No idea what a Electrolytic Capacitor is and also have No idea where to look for it in the radio any way, finding what has been found hasn't did me any good yet so far & finding a Diagram for the Electronics wouldn't be any easier.
Old 10-23-2016, 07:37 AM   #14
ck5566
I'll get back to you after some Much needed sleep
Old 10-23-2016, 09:24 PM   #15
ck5566
UP DATE ALL. I should have mentioned at first that all I wanted to do was BENCH TEST it first be for installing it. So when you want to test it but not install it Both the Yellow & red wires need to be together for the test. Radio works just fine. Thanks to all that contributed to this thread and its posts.
Old 10-24-2016, 10:34 AM   #16
michael bustamante
haha i wish i knew that first!! lol
1967custom
Old 10-24-2016, 11:07 AM   #17
ck5566
As painful as it is to admit-
The kicker here is I was a Electrician for 32 yrs.
Old 10-24-2016, 12:22 PM   #18
davepl
davepl's Avatar
I found the circuit diagrams and so on for it as well, but didn't see any value in posting them, but if you do need to do board-level repairs, those instructions are out there.
Old 10-24-2016, 12:24 PM   #19
demian5
demian5's Avatar
Id go get a bluetooth stereo with cd if I was going through all this trouble
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 10-24-2016, 01:21 PM   #20
ck5566
I am retired now so with keeping up 5 cars & 1 truck along with my Harley Oh yah I forgot the Wife,kids & Grand kids,the House at least its payed off, extra money gets spread around thinly if you know what I mean. The radio/cassette was just collecting dust and with my working AM radio in the truck well the FM/AM/Cassette is a No brainier not to install
PS; there is still people that has cassettes you know. He!! I even have a working Craig Pioneer 4 track with around 20 4 track cartridges. Did I forget to mention my 8 track also. Life goes on so what ever Floats your Boat go for it.
