10-26-2016, 11:28 AM | #1 |
1997 C1500 Rear Disc?
I am looking into doing a rear disc swap on a 1997 C1500.
Been thinking of finding a late 90's caprice rear with disc this way i can get the disc and a narrow rear. Or i may narrow my rear and do a disc conversion? How will this affect the stock master/prop valve and the ABS system? What is the best route to take on this conversion? Going with a 20" Raceline wheel.
1961 Biscayne http://67-72chevytrucks.com/vboard/s...90#post6978790 SOLD 1971 C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=656258SOLD 1966 Suburban http://67-72chevytrucks.com/vboard/s...85#post7323885 |
10-27-2016, 07:43 AM | #2 |
Re: 1997 C1500 Rear Disc?
I would just pick out a rear disc brake kit and install it.Its a lot easier then a rear end swap that never came in your truck.Plus the car rear ends are weaker then a trucks.
10-27-2016, 08:18 AM | #3 |
Frequent Flyer
10-27-2016, 08:50 AM | #4 | |
Did you do rear discs on yours?
10-27-2016, 09:01 AM | #5 | |
10-27-2016, 12:09 PM | #6 |
Frequent Flyer
I have not but plan to use this kit in the future.
10-27-2016, 02:01 PM | #7 | |
A different bore master cylinder might also be desired to help dial in pedal pressure vs stopping performance.
10-27-2016, 03:46 PM | #8 | |
10-27-2016, 04:14 PM | #9 |
I would research bore size for those early 2000's trucks spec'd w/a disc/disc set-up & compare.
