Old 10-26-2016, 12:20 PM   #1
forestb
forestb's Avatar
Same shocks for coils and bags
I have a rear shock that needs to be replaced because it is leaking. In the future I want to install air bags. If or when I get bags the plan is to keep the ride height around the same. My question then is will one shock do the trick or do I need to get new shocks when I get bags? Also what is a good shock? I am looking for a comfortable ride more than high performance. But both would be grate.
forestb is offline   Reply With Quote
Old 10-26-2016, 04:33 PM   #2
bbbc10
Diggin The SquareLife
Re: Same shocks for coils and bags
Depends on how big of a notch your gonna do and how low your gona want it to go
bbbc10 is offline   Reply With Quote
Old 10-26-2016, 04:44 PM   #3
forestb
forestb's Avatar
Most of my reason for bagging it is to get a smoother ride. So it will mostly be staying around the same height. I might add a small c notch in the future but nothing much more than that. I already have 4 inch drop coils in the rear and a one inch block. The shocks have been relocated.
Old 10-28-2016, 10:36 AM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
It's all about travel. If you keep the compressed and extended lengths the same with bags as you do with your current setup, then you don't need to change anything. If you are going to notch the frame, which you don't currently have, you will change your compressed length as the axle will go lower. You will need to make sure your shocks can handle the extra compression. If you change nothing but swapping the springs out for bags, you won't have to do anything.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-28-2016, 11:23 AM   #5
forestb
forestb's Avatar
Thanks. Are there any shock recommendations. The white kyb shocks are what someone else recommended.
Old 10-28-2016, 01:46 PM   #6
chevy_mike
chevy_mike's Avatar
I am running Bilstein shocks, which is all I try to use regardless of vehicle.
Old 10-31-2016, 11:42 AM   #7
forestb
forestb's Avatar
Which type would work best for a 62 chevy c10
Old 11-02-2016, 11:27 AM   #8
MCB Matt
MCB Matt's Avatar
Check out the Ridetech Billet Shocks. The HQ - Single Adjustable is by far the most popular we sell. These are used on Bagged and static coil trucks and WILL give you the smooth ride and handling you are after.
They are made by Fox racing to Ridetech's own specs and valving.
Let me know if I can be of help on them, we are Ridetech's largest Distributor in the US.
MCB PARTS
MCB - Matt's Classic Bowties
5360 Gateway Plaza Dr.
Benicia, Ca. 94510
925-828-5555
www.mcbparts.com
Email: forums@mcbparts.com
Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
Hours: Monday to Friday 8am - 4pm Pacific
We ALWAYS enjoy talking to our customers!
We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
MCB Matt is offline   Reply With Quote
Old 11-02-2016, 10:23 PM   #9
forestb
forestb's Avatar
I will take a look.
MCB PARTS
