10-29-2016, 10:50 AM | #1 |
99 Tahoe turn signal switch issue-Lights flickering
My 99 Tahoe turn signal switch is having issues. When my lights are on and I move the tilt wheel the headlights flicker with each setting that the wheel moves and locks into. My friend takes dash and cover off of steering wheel and we discover a wire barely hanging on, a bit corroded and the rubber covering the wire rubbed off due to rubbing when wheel is tilted. He says this type of harness has to be replaced due to the way it's wired into the harness. Has anyone here ever have an issue with their turn signal switch harness and was able to just fix the wire and not have to get a new harness?
1974 C10 swb 350 1977 3/4 ton Silverado 454 1999 2 door 2wd Tahoe |
10-29-2016, 02:54 PM | #2 |
Re: 99 Tahoe turn signal switch issue-Lights flickering
1) You're in the wrong forum section, the 99 Tahoe is a GMT-400 platform which is the 88-98 section.
2) Here is a picture of the multifunction switch assembly. The portion of your harness that has failed is likely one of those wires and the harness is not separate from the switch. Quickest/cheapest repair is to solder the wires back together. Alternatively the Dorman replacement multifunction switch assembly s ~$52 from Amazon.com. I don't know what the quality of their electrical components are, some people don't mind them, I personally use Delco parts. Could also lookup vehicle on rockauto, search for the multifunction switch and look at their offerings.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
10-29-2016, 06:13 PM | #3 |
Thanks for the reply 83gmc. Yeah I saw that one on Amazon and I'm waiting to hear back from therm about their warranty. Was on rock auto and saw some by Airtex And standard and was wondering if the make good quality stuff? Sorry bout putting this in wrong forum
