Old 10-30-2016, 12:06 PM   #1
Dustmaker65
Dustmaker65's Avatar
Looking for Serpentine Belt options
Getting ready to build a 350 for a truck. Don't have any pulleys or brackets to start with, so figured I would just do a serpentine belt drive. This truck will have a Vintage Air IV kit, so I will need A/C brackets.
Anyone have any ideas to help me out?
Thanks!
Jimmy
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 10-30-2016, 12:10 PM   #2
LongBox
Re: Looking for Serpentine Belt options
If this was my problem, I'd be going to a wrecking yard, and grabbing the complete bracket, tensioner, alternator, etc from a later model truck with the 350. The only thing I'd worry about is that the block and heads you use need the mounting holes for the serpentine brackets.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 10-30-2016, 12:21 PM   #3
atm70chevy
atm70chevy's Avatar
That's exactly what I did. Got all the pulleys, tensioner and power steering pump for $75.00.
atm70chevy is offline   Reply With Quote
Old 10-30-2016, 12:39 PM   #4
Longhornss
Thanks!
Jimmy
I guess this all depends on your budget. There are several high dollar billet systems out there.
Then you have the GMPP kits that are basically a factory unit, sold as one kit
then there is the of wrecking yard take offs.
The biggest concern with any of these is getting a compressor/bracket that works with the vintage air. VA recommends using sanden compressors, which are generally what you will find on any of the aftermarket billet kits.
Some of the factory GM brackets use "pancake" style compressors typically found on the later g body cars and corvette's. I have used these compressors with vintage air kits and had success as well.
Longhornss is offline   Reply With Quote
Old 10-30-2016, 02:11 PM   #5
Dustmaker65
Bad thing about junk yards around here is that you get what they pull. You stop by and tell them what you want, and they pull it off the cars. They don't allow no one in the yard.
Jimmy Hoelzel
Old 10-30-2016, 02:11 PM   #6
BossHogg69
motor exploder
BossHogg69's Avatar
Vintage Air makes a bracket to mount a Sanden compressor in place of the 'pancake' R4 compressor, part #141805. I have one with along with the aluminum brackets that I got off a '93 model 5.7. You use the aluminum serpentine drive from an 88-95 4.3/5.0/5.7 (pre vortec) and this bracket allows you to use Vintage Air's recommended compressor. OR, you could just use the R4 style. It may work with other factory serpentine brackets, but I don't have personal experience with them.
I'm using the VA Gen IV, but after I rounded up the parts I didn't care for the looks of the factory style setup, so I ended up getting one of the March Pro Track systems. Functionally, the factory brackets work fine, I just wanted a different look.
a couple of threads about it:
http://67-72chevytrucks.com/vboard/s...d.php?t=585944
http://67-72chevytrucks.com/vboard/s...d.php?t=413940
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
