Looking for a right hand engine perch for a 292 engine for my C-10 Please check your parts and look in all your nooks and crannies, there must be one hiding out there somewhere. Thanks, Donn
#2 | |
Active Member
![]() Join Date: Oct 2002
Re: MI-WTB 292 RH Engine Perch
need to dig them out first. Pm me later, I can try and send pics |
![]() Join Date: Jun 2009
Are they different from the 250 mounts ? I have a pair of those if they will work, 20.00 + shipping
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
![]() Join Date: Oct 2009
Yes. The left side is the same between 250 and 292 but the right side is different because of the fuel pump location.
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
Thanks, I have the stands that came with the 70 I bought but I am not sure if it was originally a 292 or 250, how would I know or identify the mounts I have then.
If your truck has the original SPID sheet in the glove compartment it should say if it was equipped with a 292, if it doesn't mention an optional motor is more than likely came with the 250 six. I'm also told that the RH perch for the 292 is part # 3822956, but I'm not sure. Maybe someone has a book and can verify that for us. My 69 came with the 250 so the SPID doesn't mention an optional motor. Also if it had came with a 292 it should have a 292 emblem below the C/10 emblem on the side fender.
![]() Join Date: Sep 2007
is the motor mount frame stand from a 66 with a 283 the same as the one you're needing? if so i have it
1967custom |
Lol on my spid sheet,
Your sheet looks a lot like mine. Mine is about the same except the Hydromantic trans and the two-tone paint. Apparently also came with a 250 same as mine.
it looks like my mount is used on the right side for the 292. if youre interested. i can go 30. shipped to you
1967custom |
#13 |
#14 |
i can clean it up and check it out for you.
1967custom |
#15 |
![]() Join Date: Jun 2005
Classic V6 GMC's had a link showing the difference in the RH mount. The 292 mounts are the set on the right and 250 mounts are on the left. Hope that helps!
http://67-72chevytrucks.com/vboard/s...2+motor+mounts
Brian XNGH ECV Chapter 58 1972 Jimmy / Blazer Project 2wd 1974 Chevy Crew Cab Shorty |
#16 |
![]() Join Date: Dec 2009
When you guys get the mm for old51sedan, I am interested in L and R motor mounts for a 1967 k20 with a 292. It came to me disassembled, but no mounts. Thank you!
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
#17 |
#18 |
Thank you!
#19 |
Maybe he got them from you!
