Old 11-02-2016, 06:05 PM   #1
'63MurderTruck
'63MurderTruck's Avatar
Wiring new Fuse Block
First off, I have absolutely no idea what I'm doing when it comes to anything electrical.
I need to install a new fuse block on my son's truck. if someone could walk me through it, I would greatly appreciate it.
I've included pics of the old and new fuse blocks. Everything seems pretty simple except for the things that i've marked on the old fuse block.
Thanks in advance.
'63MurderTruck is offline   Reply With Quote
Old 11-03-2016, 02:30 AM   #2
leonphelps
Re: Wiring new Fuse Block
cant tell if wire is pink or red.
pink usually means ignition on hot feed.
leonphelps is offline   Reply With Quote
Old 11-03-2016, 02:32 AM   #3
leonphelps
Also, I would put a relay or two in there.
the relays would make the panel only hot when the key is on. this way your truck runs less of a risk of burning up when sitting.
Old 11-03-2016, 09:37 PM   #4
64shortbox
64shortbox's Avatar
as leonphelps stated - I would run a relay to power your fuse box so it's only hot when the ignition is "ON". Since you wouldn't have an "ACC" or " Battery" the ignition would have to be "ON" for the radio to work & also the instrument lights, tail, brake & running lights but I really don't see where that would be a problem.
64shortbox is offline   Reply With Quote
Old 11-04-2016, 12:38 AM   #5
Captainfab
60-66 Nut
I would not run all circuits from a key on source. It is nice to sometimes have your lights, turn signals and 4 ways available without having to have the key on. However I would fuse/breaker those for safety
