Old 11-04-2016, 05:09 PM   #1
evan
evan's Avatar
Air ride without steering and bed modifications? (1980 C15)
I'm planning a new project with a friend on a 1980 GMC C15 and we're thinking about using air ride. Neither of us has used it before. Our goals are to improve handling, cruise at a ride height similar to a 4/6 or 5/7 static drop and then park as low as possible without steering & bed mods. Is it still worth it to spend the money on air if we're going to leave the steering and bed stock?
I see the Ridetech level 1 kit reuses the factory control arms so I'm assuming it's not necessary to modify the steering. Does the rear four link in that kit require bed modifications? Are there other options we should consider?
Thanks for reading.
Evan B.
evan is offline   Reply With Quote
Old 11-04-2016, 10:06 PM   #2
bbbc10
Diggin The SquareLife
Re: Air ride without steering and bed modifications? (1980 C15)
Ur gonna have to do steering shaft mods an no bed mods have to be made wth that bolt in notch.....i would search the forum for morr info before buying
bbbc10 is offline   Reply With Quote
Old 11-04-2016, 10:10 PM   #3
evan
evan's Avatar
Thanks for the reply. I did a better job searching after I posted but couldn't figure out how to delete this.
I haven't found anything about having to do steering shaft mods though. I thought they were only necessary when you replace the crossmember. I'll do some more searching about that.
Evan B.
Old 11-04-2016, 10:47 PM   #4
tinydb84
tinydb84's Avatar
I had that kit in my brother's truck. No steering mods. No bed cutting. Didn't get very low though. It rode great. Not worth the price though. You can get a similar kit from board vendors for a much cheaper price.
David
Instagram: myfabguy
Old 11-04-2016, 11:09 PM   #5
evan
evan's Avatar
Which vendors are you thinking of? I checked the suspension marketplace but there's no vendor list and about a dozen posts from 2016.
Evan B.
Old 11-05-2016, 12:14 AM   #6
tinydb84
tinydb84's Avatar
Travis at AZ Properformance will put together a good package for you. AVS doesn't advertise here anymore but will do the same.
David
Instagram: myfabguy
Old 11-05-2016, 03:10 AM   #7
andrewmp6
This is that kit installed http://67-72chevytrucks.com/vboard/s...d.php?t=344982
andrewmp6 is offline   Reply With Quote
Old 11-05-2016, 03:13 AM   #8
andrewmp6
And like said Travis at http://www.azproperformance.com/home.php he is a vendor on here,You can call or email him he might have some kinda discount if you tell him your a member on here.If not still worth buying off him,He carries a lot of parts and kits knows then well and i never heard a single bad thing about him.
Old 11-08-2016, 11:08 PM   #9
Pro Performance
Pro Performance's Avatar
Thanks for reading.
As mentioned above, no steering mods with this kit. RideTech does make a nice product, but are other options out there. Be glad to help in any way.
Travis
480-420-8175
travis@azproperformance.com
Thanks and appreciate it.
Pro Performance is offline   Reply With Quote
