Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-06-2016, 10:22 PM   #1
blazer_mtl
restore a blazer K5 and change it to 2 wheel drive
Hi,
I need member expertise... The plan is to put a body of a K5 Blazer (4WD)on a C10 long bed cutted frame(2WD)?
I want to do a 1972 C5/Blazer... because I can't find one for a good price...
Question #1: Is the frame over the rear axle, is the same shape for both (C10 and K5)? I'm planning to put the cab box bracket from the frame of the K5 on the C10...
Question #2: Wheel base of K5 is 104 po. and C10 lwb is 127 po... if I cut the frame in the straight section 23" off like they do in the brother`s truck conversion kit LWB to SWB, is it ok? Plus extra cut on the rear end of the frame to fit the bumper...
Does I'm doing right?
blazer_mtl is offline   Reply With Quote
Old 09-05-2018, 06:32 PM   #2
67see10
67see10's Avatar
Re: restore a blazer K5 and change it to 2 wheel drive
not sure why there isn't any direct information on the truck frame to 2wd blazer conversion. I've been looking through old threads for weeks
67see10 is offline   Reply With Quote
Old 09-06-2018, 08:57 PM   #3
raggedjim
raggedjim's Avatar
Here's one...
http://67-72chevytrucks.com/vboard/s...g+frame+blazer
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 09-06-2018, 09:41 PM   #4
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Why not convert the existing frame to 2wd?
I did one with the help of Liverat a few years ago, and I know he has done several..
http://67-72chevytrucks.com/vboard/s...d.php?t=327847
More pics with better views of the frame and how we converted it to a bagged C/5 using stock front 2wd crossmember, and trailing arm rear..
https://www.flickr.com/photos/hiking...10765391/page1
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 09-07-2018, 06:44 AM   #5
notsolo
notsolo's Avatar
x2... 4x4 frame fits in all the right places. Cross member with trailing arms from donor....also front cross member 5 lug disc, 2wd steering box...trans cross member...... A couple photo's of mine.
notsolo is offline   Reply With Quote
