Old 11-08-2016, 10:11 PM   #1
Flying Hamster
Flying Hamster's Avatar
Hopefully they spay/neuter...
the that decided to attach the clutch master cylinder and pedal with plastic twist-on connections. Just had the master cylinder fall off as the bracket broke off...
Seriously, let's get the engineers and bean-counters responsible OUT of the GENE POOL!
Flying Hamster is offline   Reply With Quote
Old 11-08-2016, 11:55 PM   #2
Matt Man
Matt Man's Avatar
Re: Hopefully they spay/neuter...
Any truck past 87 started going downhill.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 11-09-2016, 09:58 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Its a known issue on these. They figure anyone still buying a truck with a manual is over 70, so you won't outlive the lifecycle on the plastics
A good friend of mine does OEM engineering of all sorts of stuff for GM 3rd party vendors. You'd be extremely surprised by the reasoning behind things like this. While it seems dumb (and kinda is dumb), there is usually a reason beyond cost. For example, its possible those fastners were spec'd to sheer at a certain load, in order to prevent damage to something else in the system. Plastics also get used in situations in which multiple types of materials are being fastened together, to help prevent issues like galvanic corrosion.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
