Old 10-11-2003, 12:31 AM   #1
krazy_texan
krazy_texan's Avatar
burb quistion
i am looking at buying a 66 suburban it has already been lowered but i was wondering what it would take to add power steering in it and what i could pull the steering out of, the truck currently to a body man and needs very minimal body work done to it but has no motor, i am going to put a 350/350 combo in it and he had a 327/350 in it the 350 i have already has power steering set up on it but what could i get a box out of, also any info on this truck would help, i plan on putting a back seat in it that is easily removable like in a minivan or something and buckets up front and painting the truck light blue and white (it is in primer) but any and all help would be appreciated
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 10-16-2003, 01:25 PM   #2
dvalentine
You can use the P/S box out of a 72 and later truck. If you can, find a doner that has everything you will need. P/S box, P/S pump, pump mounting brackets and crank pully.
Ues an adapter plate from REZ Engineering and follow their directions. Some welding of the column shaft is required to shorten it.
I used a P/S box from Mullins Steering Gears that was performance tuned for 3 turn lock-to-lock. I was glad I did.
I installed a tilt column and Borgensen vibration dampner on the column and connected it to the box with a DD shaft and another Borgesen U-joint. Everything bolted up to the REZ adapter in an afternoon with no welding required.
The REZ adapter is the ONLY way to do this. It mounts the box in perfect alignment and has a backing plate that reinforces the fram from stress cracking.
DV
dvalentine is offline   Reply With Quote
Old 10-29-2003, 05:18 PM   #3
rodnok1
rodnok1's Avatar
rez kit is great, if the extra hole you have to drill is off even a little it doesn't line up. Finding hoses locally that fit correctly based on your p/s pump and brackets can be time consuming. I have the NAPA numbers I used laying around if you want them.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 11-26-2003, 05:17 PM   #4
NAPCO ken
NAPCO ken's Avatar
Please post those NAPA numbers for the PS hoses that you used. Thanks.
ken
'58 Chev NAPCO 4x4 short
'60 GMC Suburban 4x4, restored
'60 GMC 3/4T stepside 4x4
'64 GMC Suburban 4x4, restored
'90 Chev Suburban 4x4, dually, ZZ502
'77 GMC Suburban 4x4, one ton axles, 12" lift, 39.5"s
'88 Chevy crewcab dually 4x4, 10" lift, 42"s (x6!)
'03 Jeep Wrangler Rubicon
'79 Chev 3/4 Suburban 4x4, 400-400-203
NAPCO ken is offline   Reply With Quote
Old 11-26-2003, 08:00 PM   #5
rodnok1
rodnok1's Avatar
Napa part number for power steering hoses
7-1201
7-1536
These were the closest i could find for the early pump and box. Still required just a little tweaking, but they have been on well over 6 months and no problems
Good Luck.
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
