11-21-2016, 11:15 AM | #1 |
NP833/MY6 4-speed OD Transmission
I have had this for a few years, started to use it in a project but went a different direction and it's just collecting dust. If you are not familiar with these transmissions, they are a 4 speed manual overdrive produced by GM in the 80's which have gear ratios similar to a 700R4. They have a small cult following and the best place for information on the web is right here.
I bought this used and then sourced a bellhousing for it. It is complete but I have not tested it! My plan was to seal the side cover and give it a try, if there were any issues I planned for a local rebuild. The shifter and knob are nice, I thoroughly cleaned the shift assembly and greased it. There is a new TO bearing. The only thing I would do is tap or insert the bosses for the shifter assembly bolts. The holes aren't wallowed or damaged, just not tight as I would like. I didn't really look closely, just bolted the shifter up for mockup. This will make a cool swap for somebody! $500 firm. local pickup preferred.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
11-22-2016, 03:49 PM | #2 |
Re: NP833/MY6 4-speed OD Transmission
Cleaning out the garage...going into storage. What are the odds this is the only COMPLETE one for sale anywhere?
11-22-2016, 04:16 PM | #3 |
Can you check shipping on that to 98409. What does it weigh stripped down?
11-23-2016, 11:10 PM | #4 |
I will check on that. I would probably need to separate the bell and shifter and build a small crate/box. My time for that is in short supply, so honestly it might take a few weeks, so long as you're not in a hurry. I bet it all weighs 120lbs-ish.
11-23-2016, 11:19 PM | #5 |
Contact Fastenal via their website with the dimensions, approx. weight, they will reply with a quote. All you have to do is drop it off to them and they strap it to a pallet and ship it.
12-12-2016, 02:16 PM | #6 |
Sale pending.
12-30-2016, 12:19 PM | #7 |
Sold!
