11-23-2016, 02:49 PM | #1 |
Is this even possible? -New Guy Question
So I spent the summer upgrading Gramps 59’ GMC to make it safe/reliable enough to go on a 300 mile fishing trip up in the Sierras. (Made it over the 10K’ Sonora Pass!) Last thing on my list to do is swap out the original steering column for a collapsible unit. Trouble is, I want to keep my original 3 on the tree shifter. Not finding an application in the aftermarket for such a column. Is it even possible to do?
Just for reference, the truck had 92K on it when Gramps past and in the last 25 years I’ve put another 40K on it. Original 270 with only a valve job done by me in the 90’s. I’ve already installed seat belts, split the brake hydraulic system, new shocks, tires, drilled drums, tapered bearings and replaced the original bed wood. Truck is still wearing original paint. (What’s left of it.) and has never had a radio or speaker installed. I’d like to keep it as original as possible but the column scares me. Has anyone installed a collapsible column in one of these w/o going to a floor mount shifter? Thanks, -San Jose Steve |
11-23-2016, 06:05 PM | #2 |
Re: Is this even possible? -New Guy Question
We had a '75 or '76 Malibu with a three on the tree. That car would have had a collapsible column. I can't tell you where to find one today, though.
11-23-2016, 07:01 PM | #3 |
That is Cool history on your truck! But i am just saying here, a newer steering column is
not going to make the truck that much safer, Its a good first start to making it safer Yes, But, God Forbid, You, or any of us gets in an accident in one of an AD or TF trucks! again i am just saying, the early iron is not that friendly to one's safety. Allen |
11-23-2016, 08:34 PM | #4 |
you really can't modify the existing column without modifying the whole steering system
your column is a fixed shaft attached into the steering box you say collapsible column, make sure you don't mean tilt column or telescoping column collapsible only collapses in a wreck, yes it's a safety feature, but the steel dash would kill you anyway i'm going to assume you mean tilt steering wheel: see line 1
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-23-2016, 09:54 PM | #5 |
If you want a collapsable column for safety reasons I'm thinking that 69 though 72 Chevy and GMC pickups with three speeds had what you are looking for but you still have a lot of work involved to make one work in your truck.
What you have now is one solid shaft that runs from bottom of the steering box to the nut at the top of the wheel and you would have to cut that off above the steering box at the right spot to put in the column and hook it up to the stub of the existing shaft. If you are looking at tilt or tilt/telescope I have never seen a column shift three speed with a tilt wheel that I can remember and I am 70 years old and have seen a lot of trucks.
11-24-2016, 12:21 AM | #6 |
like said previously, the steering column is a one piece spear from steering box to steering wheel. if you wanted to you could check out ididit steering column install. they cut the shaft above the box and grind the shaft down on two sides to accept a double D shaft u joint. then,above that, you can install any steering column you can find with a standard 3 on the tree. some square body trucks (70's era chevy) had the 3 three on the tree set up, pretty rare though. check out the wreckers in your area for a donor, or there is always the floor shift conversion.
11-25-2016, 02:06 PM | #7 |
GM offered 3 speed on column clear up to about 1981 or so. Most people didn't save those columns though. Also I have never seen a tilt with 3 speed on column.
11-25-2016, 02:13 PM | #8 |
Some 3 point seat belts might be a good addition too.
11-28-2016, 07:05 PM | #9 |
Thanks...... 3 point seat belts I already have. Now I just want to avoid impailing myself on that rigid steering wheel shaft. Not interested in a tilting wheel, rather just one that will collapse a bit in an accident if it were to come up and meet me on my bench seat! Well as Gramps used to always say; "Just go slow, you always have a chance if you go slow." Hahahahaha!
11-28-2016, 07:30 PM | #10 | |
11-28-2016, 08:43 PM | #11 |
stock steering box is mounted well behind the crossmember and even most of the engine. If you have decent belts you don't have much to worry about there. It's hard to do much with the steering column and box with going all the way to a PS replacement.
Cool truck, BTW. I'm an engine builder and I've built several of those 270s for guys. With minor update/mods they wake up and run pretty good. Last one I did the owner came up with an Offy 4-bbl manifold. we welded on a Q-jet adaptor and cleaned up the inside a bit. It had a split exhaust manifold with a small cam. He had a conversion distributor that turned it into an HEI. Thing ran like crazy for 300 inch engine. Off idle torque was murder with the Q-jet. He came up with some OD manual trans setup, it was ready to rock'n'roll on the streets or the highway. I was really impressed with the whole setup and most people would not notice that anything major had been done under the hood. |
11-29-2016, 02:32 PM | #12 | |
11-29-2016, 06:49 PM | #13 |
Steering shaft isn't the only problem. The hood can get knocked straight back through the A pillars.
11-30-2016, 12:31 PM | #14 |
The hood knocking through the A pillars? Ugh..... you just added another item to my list of things to try and mitigate!
I already replaced the rear view mirror and glove box door screws with plastic ones hoping they will break away if hit hard enough. Gas tank relocated under the bed with a modern filler tube. The hood thing is crazy. Never worried about it much, but now that I compelted a 300 mile R/T on the highway, I want to do more which unfortunately increases the risk of hurting myself while driving this thing! -Steve |
11-30-2016, 12:53 PM | #15 |
Just saying here, The Truck, is what it is, and is "not" what a vehicle is by today's Safety standards,
with that, you might want to sell the truck and get yourself a Prius! |
11-30-2016, 01:07 PM | #16 |
Steve, I'm betting that many of us "long haulers" here have the same advice: Drive defensively. It's going to be extremely difficult to make an old truck as safe as a new one. Part of the reason trucks look like they do is to accommodate all the safety features built in. Don't drive aggressively, look ahead for trouble, stay out of the path of danger and the odds are in your favor.
FWIW if I were building for safety I would assume there's no way to keep a sitting person perfectly safe during a crash in that old truck (remember that I have one, too). There's nothing designed into the cab or chassis to absorb the energy of an impact and I don't think trying to fight it will end well. I'd install a two piece column, use a shoulder belt with no lap component, latch the pivoting stock seat so it won't fold, make as much room around and under the dash as possible, clear up any sharp edges down there, and plan to end up on the floor possibly with broken legs in the event of a significant crash. |
11-30-2016, 01:15 PM | #17 |
Yeah..... I know..... I've gotten buy the past 25 years driving it only to Home Depot and occasionally to Monterey hauling dive gear. Never thought it would actually make a long drive across the state though. Now that I know it can, I want to drive it on all my fishing trips! :-)
I suppose if I wanted to stay safe, I'd be better off in my Dodge Challenger R/T. Then again...... that thing encourages a lot of "Bad Behavior". :-) -Steve |
11-30-2016, 02:28 PM | #18 |
there is no way to make these trucks safe in a wreck
no crumple zones, the trans x-member is designed to launch the motor into the cab doors that pop open in a wreck and A/B pillars that fold like paper in a wreck drive it defensively: i have driven over 1M miles in these trucks, coast to coast and border to boarder a few times mostly safe miles and one youthful transgression that i have paid for over and over again
11-30-2016, 02:38 PM | #19 |
Fill the Cab with Bubble Wrap! Just Kidding Lol...
Be Careful and I do wish you "SAFE" Journeys in your truck! Allen |
11-30-2016, 03:55 PM | #20 | |
11-30-2016, 08:02 PM | #21 |
12-01-2016, 01:25 AM | #22 |
Right. The stud, combined with a weakened "crumple zone" in front of the hinge mounting, caused the hood to buckle rather than shear the bolts. The pin was actually called an "Anti- Guillotine Pin."
