Old 12-02-2016, 06:26 PM   #1
Pablo_65c10
1964 c10 build
So i think I'm going to start writtting and posting about my build, I bought the 64 in may 2015, I have done a lot to it, I least I think I have since this it's my first time working on anything like this before, when I bought the truck it had a 5.7 vortec and a 4l60e, and a lot of rust and a lot of bondo in top of it 😂😂, That just meant that I had to learn how to weld and how to be patient, like I said before, I think I have done a lot to it since I bought it, but since I don't have a garage or the tools its been slower that I would like. This forum have help me a lot, it been before I had the truck I spend a lot time researching and reading a lot of you guys builds. Thank you !!! I will be posting all i have done since I first bought it.
Pablo_65c10 is offline   Reply With Quote
Old 12-03-2016, 12:47 AM   #2
Captainfab
60-66 Nut
Re: 1964 c10 build
Welcome to the forum
It appears that the engine is currently not running? Has the harness been modified and the PCM reflashed yet?
Old 12-03-2016, 01:42 AM   #3
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 1964 c10 build
Welcome aboard.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-03-2016, 01:59 AM   #4
62stepside longbox
62stepside longbox's Avatar
Re: 1964 c10 build
Nice truck, I really like the look it has with the 61 Apache hood
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 12-03-2016, 02:50 AM   #5
Pablo_65c10
Re: 1964 c10 build
Thanks captainfab, when i bought the truck the engine started but I didn't run so I did I little bit of research and I found out the 4l60e had a mechanical speedo sensor on it, so I bought a sensor for a 1998 c1500 and a new gear, installed and I got the truck running, I guess the previews owner got the engine and trans from different vehicles, I'm thinking they got the harness and pcm fix too.
Old 12-03-2016, 02:58 AM   #6
Pablo_65c10
Re: 1964 c10 build
Thank TJ !!! I been looking at the two tone project you got going on for a while now, I'm working on my cab rite now and the pictures of your cab inspire me to keep on grinding ����
Old 12-03-2016, 03:03 AM   #7
Pablo_65c10
Re: 1964 c10 build
Thanks nik, you know I still don't know if I want to run the Apache hood or find one for a 64, I really like the progress you done to your truck tho, a lot of talent man.
Old 12-03-2016, 04:01 AM   #8
Pablo_65c10
Re: 1964 c10 build
This was my first time driving the c10 and a non power steering veichle 😂😂
Old 12-03-2016, 12:09 PM   #9
Bomp
Bomp's Avatar
Re: 1964 c10 build
If you decide to change your hood don't sell this one. You might have a change of mind and switch back one day.
Like what you're doing.
Sub'd
Bomp is offline   Reply With Quote
Old 12-03-2016, 03:46 PM   #10
Pablo_65c10
Re: 1964 c10 build
Sub'd
Yeah good idea. And thank you sir.
Old 12-03-2016, 04:14 PM   #11
Pablo_65c10
Re: 1964 c10 build
So I soon as I got the truck I started to see If I was going to have to buy a new engine and trans because I didn't know if the engine or trans ran, so I did the essentials, top up the fluids, engine and trans, hook up the radiator, check the wiring, new fuel pump relay, the truck had a gas tank from a blazer in the back of the bed. Everything work ok, runs fine, shifts ok after I got the speed and gear install on the 4l60e, temperature is normal, I haven't check the oil pressure because it pretty hard to get to the port in the back of the engine. What I'm thinking is that I'm going to keep that set up, and if for some reason it dies I'm going to do an Ls swap later on.
Old 12-03-2016, 05:42 PM   #12
Pablo_65c10
Re: 1964 c10 build
This was after I got the truck running, I started to take the front end apart, the radiator support was rusted out in the bottom part, the inner fenders had rust in top part where it meets the rad support and a bunch of holes in both of them, at the time I didn't have a mig welder, so I took the to a local shop to see if they could fix them for me but they wanted a lot of money so I went ahead and bought new inner fender and the radiator support and battery tray. I still have the originals, just in case I have fitting problems later on, I think I can fix them my self now.
Old 12-05-2016, 09:23 PM   #13
Pablo_65c10
Re: 1964 c10 build
Before I put the new inner fenders I remove the control arms to install new ball joints and tie rods, then I wire wheel the front part of the frame, Then I used some summit racing chassis paint, then I moved to the back, took the bed of and I started to take apart the rear suspension, I had to grind and cut off most of the rusty bolts. Same as the front, degrease, wire wheel , and then paint.
Old 12-05-2016, 11:13 PM   #14
step65
Re: 1964 c10 build
Looking great cleaning up real nice.
step65 is offline   Reply With Quote
Old 12-06-2016, 12:47 AM   #15
pimpston65
pimpston65's Avatar
Re: 1964 c10 build
aint much to em when you start takin parts off, makes it easy to paint and work on...
pimpston65 is offline   Reply With Quote
Old 12-06-2016, 01:11 AM   #16
Bomp
Bomp's Avatar
Re: 1964 c10 build
Have to make a Safety comment.
I see in the pic you have the frame rails resting on the cement blocks.
Cement blocks can burst/fail at any moment without notice. ~friend of my dad died due to failed cement blocks~
Please do not use cement blocks. Please use jack stands or wood blocks.
You have a great build under way and would hate to see you get hurt.
concerned truck guy,
Bomp
Old 12-06-2016, 12:25 PM   #17
Moarplease
Re: 1964 c10 build
Bomp
Or at least flip the blocks correctly so the cores are vertical and the block can take the load as designed. Safety first.
Adam
Moarplease is offline   Reply With Quote
Old 12-06-2016, 12:27 PM   #18
Pablo_65c10
Re: 1964 c10 build
Thank you, and Yeah a little bit of cleaning and paint makes a big difference.
Old 12-06-2016, 12:33 PM   #19
Pablo_65c10
Re: 1964 c10 build
Yeah, I was pretty intimidated at first but once I starded to take parts off, it got really easy.
Old 12-06-2016, 12:40 PM   #20
Pablo_65c10
Re: 1964 c10 build
Bomp
Thank for the advice bump, appreciate. I did used some jacks and the tires and rims in the bottom of the cab just in case.
Old 12-06-2016, 12:43 PM   #21
Pablo_65c10
Re: 1964 c10 build
Adam
Yeah makes a lot more sense now that I'm seeing the picture. Hopefully I don't have to use the block anymore. Thank you.
Old 12-09-2016, 11:10 PM   #22
Pablo_65c10
Re: 1964 c10 build
After the front and back of the suspension was clean and painted I order a 3/5 drop kit from cpp, (lowering springs, shocks and adjustable panhard bar).not the smoothest ride but I plan to do front disc brakes and drop spindles in the future.
Old 02-06-2017, 10:45 PM   #23
Pablo_65c10
Re: 1964 c10 build
Started to work In the cab, a lot of rust. Slow progress but I'm learning as I go.
Old 02-06-2017, 10:49 PM   #24
Pablo_65c10
Re: 1964 c10 build
Old 02-06-2017, 10:53 PM   #25
Pablo_65c10
Re: 1964 c10 build
