Old 12-02-2016, 09:45 PM   #1
jocko
jocko's Avatar
C20 17.5 wheels and disk brakes...
While there's lots of diameter there to play with, am assuming the narrow 5.5 width might result in the inner taper of the wheel, or possibly, the inner flat part of the large dia wheel, not being able to clear a caliper. Has anyone done front disks with stock 17.5s? Just curious. Thanks.
Old 12-02-2016, 09:49 PM   #2
oem4me
Re: C20 17.5 wheels and disk brakes...
Good question. I'll piggyback on your question and ask the same about the rare 19.5 X 5.25's.
Old 12-27-2016, 11:47 PM   #3
jocko
jocko's Avatar
ttt. still curious if anyone has attempted this.
Old 06-04-2017, 10:03 PM   #4
Classic v6 GMC's
Classic v6 GMC's's Avatar
Bringing this back to the top for 19.5 wheels.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 06-12-2017, 09:50 PM   #5
jocko
jocko's Avatar
ttt for any of the tall skinny C20/30 wheels with disk brakes added (not locking rims, talkin bout 17.5/19.5 steelies. Anyone done this?
Old 06-13-2017, 01:13 AM   #6
aotte1
Not an exact answer, do know the original 16x5.5 6 lug, 3 nub wheels, work on a 1978 Dana 44 front axle, with disks. Have a 17.5 6 lug will try to put it on same Dana axle with factory disk brakes. These are all 1/2 ton applications. Not sure how the 8 lug SRW disks design differ, along with 2 and 4 wheel drive applications. Will examine both 17.5, 6 and 8 lug wheels for BS and rim design for differences. I think the 19.5s have a different BS, then the 17.5s.
Les
aotte1 is offline   Reply With Quote
Old 06-13-2017, 08:02 PM   #7
buds56
buds56's Avatar
In the early 80's I had a 71 GMC 3/4 4wd with disc front brakes with 9.50 x 16.5 tires and 4.10 gears.
I had bought a car about 3-400 miles away and needed to pick it up. I worked in a salvage yard and had to watch every penny.
We had an old (58 or 59) 8 lug truck in the yard with a set of 7.00x17's with tubes and split rims, the tires were like new tread wise but very old Firestone "gum dipped" highway tread.
In hindsight this wasn't real bright on my part (I seem to remember them being a bit dry rotted, but heck they had tubes in them) but I put them on my truck because they were so tall compared to my 16.5's I figured my fuel economy would improve similar to putting 3.73's in the truck for the road trip.
They fit on the truck fine and I had no problem on the trip
Just one example of some of the stupid stuff I did when young
buds56 is offline   Reply With Quote
Old 06-13-2017, 08:52 PM   #8
Classic v6 GMC's
Well I found the answer I needed for my 57 van. I took one 55-59 19.5 and one 60-68 19.5 and tried them on the front of a 2008-ish Chevy van. They both fit.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 06-13-2017, 09:23 PM   #9
jocko
jocko's Avatar
No way! That's good news. Don't suppose you have a 17.5 lying around you could check?
Old 06-13-2017, 09:57 PM   #10
Classic v6 GMC's
I do not have regular access to the van but next time I do I will try a 17.5 wheel.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 06-13-2017, 10:19 PM   #11
jocko
jocko's Avatar
that would be great, thank you. So, a 2008 would be lug centric but same bc, if I'm not mistaken - with slightly different (metric) studs(?) Any details on the swap you're thinking about or are you just using the 2008 as a basis for comparison for caliper interference?
Old 06-13-2017, 11:10 PM   #12
Classic v6 GMC's
Yes they are lug centric but same bolt pattern. The swap uses 2003 and up chevy 2500 parts and I wanted to make sure the old wheels would clear the caliper before purchasing.
Here is the link to the bracket kit for the swap.
http://www.thehollisterroadcompany.c...converion.html
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
17.5, c20, disk brakes
