Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 12-04-2016, 02:26 AM   #1
dooce
Suburban/Truck seat compatibility
Does anyone know if the seats out of a 60-66 truck will bolt into the front of a 64 suburban? I bought a project suburban recently and it came without a front seat. Are the suburban front seats hard to find? I know the issue with rear access with a truck seat, just trying to figure out if it will actually bolt in.
1976 Chevy 1/2T 2wd SWB
327/Saginaw 4spd 3.73:1
LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071
LFSalleeII@gmail.com
dooce is offline   Reply With Quote
Old 12-04-2016, 02:50 PM   #2
pimpston65
pimpston65's Avatar
Re: Suburban/Truck seat compatibility
not sure if it will bolt in, as the suburban front seat has a jump seat on the passenger side to gain access to the rear seats. it may bolt in you just will have a tight fit to pass through or no access at all.
pimpston65 is offline   Reply With Quote
Old 12-05-2016, 01:11 AM   #3
dooce
I'm only interested to know if it will actually bolt it, I am not concerned about the lack of the jump seat option.
Old 12-05-2016, 01:19 AM   #4
pimpston65
pimpston65's Avatar
yeah maybe others could comment as i never tried to switch to a fixed seat
Old 12-05-2016, 07:39 PM   #5
65sub
65sub's Avatar
Well they have the same floor so I think if you drill a couple of mounting holes then the seats should fit
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 12-05-2016, 08:20 PM   #6
MusicMan70
MusicMan70's Avatar
Another thread with some good information and links to some measurements.
http://67-72chevytrucks.com/vboard/s...d.php?t=396219
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 12-06-2016, 10:24 AM   #7
bpmcgee
bpmcgee's Avatar
Don't forget that the seats have welded-in reinforcement at the bolt holes, so you'd have to add some of that too.
B
bpmcgee is offline   Reply With Quote
