Old 12-15-2016, 12:32 PM   #1
patina 66
saving a 1966 c10
i wish it was in better shape. but if it was, i wouldnt have all these stupid costly ideas in my head that will make it way cooler. but i cant decide half of the stuff. me and a friend are ripping cab apart and putting smooth firewall and redoing floors. then im putting all new inner fenders and core. the rest is staying the way nature made it, but im undecided. ive got a dual wheel 1 ton rearend and 8 lug 1 ton front. or i can get the 5 lug stuff from my 64 and tubb this one. also got a big block w 400 turbo. and i DO NOT want to build two. way outta budget. im also looking into a right side drive idea since firewall will be blank anyway so why not. gotta cut all the pedal brackets off and going w better brakes so its just some more thought into doing it. also idk if i want to go w 454 or rebuild the 250. got everything payed for just need to make up my mind and get going on it
patina 66 is offline   Reply With Quote
Old 12-15-2016, 12:36 PM   #2
patina 66
Re: saving a 1966 c10
[attach]Name:  c10 first time on gravel.jpg
Size:  56.4 KB[/attach]
Old 12-15-2016, 02:17 PM   #3
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Welcome aboard! If that was me I'd be hopping up the 250 a little and looking at a turbo. 8 PSI makes all the difference.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-15-2016, 02:22 PM   #4
patina 66
I thought a little about that too because it would be simple to run the exhaust to turbo and theres plenty of room. but then id need some sort of blow thru carb or turbo plate and those sort of things. tap oil pan is easy oil sending is easy. im leaning toward keepin the 250 because itl b very drive-able. alot harder to justify rolling around in a 454 getting 8mpg. it would sit alot more.
Old 12-15-2016, 02:33 PM   #5
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
You'd get better mileage for sure. haha There are some cheap and simple mods you can do. You mentioned rebuilding, Summit Racing sells stock type pistons that will help bump the compression up. Also shaving the head helps to. All depends on what your looking for. Those 250's can make some decent power. I did a 292 and it's backed by a 5 speed. Will get decent mileage and make great power.
Old 12-15-2016, 02:44 PM   #6
patina 66
thanks for the reply btw. and yea. your i-6 looks amazing
Old 12-15-2016, 02:56 PM   #7
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Thanks man! Look forward to seeing the progress! Be sure to post lot's a pictures.
Old 12-15-2016, 05:36 PM   #8
Lokin4AReason
Lokin4AReason's Avatar
i sure like seeing those 6s .... and welcome to the site
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 12-15-2016, 06:19 PM   #9
Bomp
Bomp's Avatar
Welcome, Looks like an interesting build in the making.
Bomp is offline   Reply With Quote
Old 12-15-2016, 10:34 PM   #10
66WideinOhio
66WideinOhio's Avatar
Welcome to the site. I'm planning on putting a 454 in my 66 SWB Fleetside. So I'll be following along to see how yours turns out.
66WideinOhio is offline   Reply With Quote
Old 12-22-2016, 03:00 PM   #11
patina 66
thanks for the welcomes. was working on pulling the heater box. got a little more surprise
Old 12-22-2016, 07:50 PM   #12
66WideinOhio
Has this Truck been in Ohio all of its life? it sure looks like it has. Do some surfing on this site and you can find all kinds of ideals for the firewall. Keep going it will get better. Ray
Old 12-27-2016, 11:25 AM   #13
patina 66
got another one. already had frame shortened really nice job too. and 5 lug swap with disc front. and a near perfect firewall. just needs cab corners and rockers. i might build this one instead. im on the fence. idk which i like better. 60-63 or 64-66. the knee knocker is growing on me. and the firewall being there helps too. idk what to do now
