12-18-2016, 02:11 PM | #1 |
de-rusting parts
Any methods that you prefer...I'm soaking in vinegar for 3-4 days
Any faster methods?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
12-18-2016, 02:59 PM | #2 |
Re: de-rusting parts
found this to be interesting.
https://www.youtube.com/watch?v=y4yYF8gSHdA |
12-18-2016, 03:08 PM | #3 |
I have seen on various shows some eco friendly products that remove rust in a day and were safe to pour down your drain on in your yard. I was going to try one of those when I get to that stage
12-19-2016, 09:17 AM | #4 |
2WD Jimmy
I have used this with great results. It is safe and you can reuse it.
http://www.jegs.com/p/Evapo-Rust/Eva...54711/10002/-1 |
12-19-2016, 10:05 AM | #5 |
I made an electrolysis tank when I did my Blazer. really worked well at getting rid of rust. The Evaporust that Tom mentioned is great too for small pieces, but becomes too expensive if you want to derust something large.
12-19-2016, 12:12 PM | #6 |
Thanks guys for all the helpful tips...I think I'll try the electrolysis, once I get the heat in my shop working again. Bleed the lines, no help, must be the circulating pump
12-19-2016, 12:40 PM | #7 |
Muriatic acid (pool supplies) from Home Depot , Lowes etc. Submerge for 15-20 minutes, remove, rinse, done. For ferrous metals only, not aluminum. Ospho (hardware stores) for removing oxidation from aluminum. As always, gloves and eye protection needed.
12-19-2016, 02:18 PM | #8 |
Phosphoric acid is in the paint section at Lowes/HD. For large items you can get molasses from feed stores and mix 5 gallons w/ water in a trash can. Its slow.
12-19-2016, 02:26 PM | #9 |
Moderator
Muriatic (pool) acid. Done. A lot of people are scared of it. If you have common sense there is nothing to worry about. A lot of people think it costs too much. At $5 a gallon it isn't breaking the bank.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
12-19-2016, 02:57 PM | #10 | ||
"I ain't nobody, dork."
Soak parts in Molasses...
Do a youtube search. Some interesting vids that shows it to work very well. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
12-20-2016, 12:13 PM | #11 |
The problem with muriatic acid is that anything within a 10 foot radius that's made of steel will rust because of the fumes. Your tools, parts or anything else made of steel will be coated. I won't even store this stuff in my shop, I keep it outside. The only thing I use it for is to remove cad or zinc plating from nuts or bolts that need to be welded.
01-01-2017, 11:13 AM | #12 |
x2 on Evaporust - - it is amazing
