12-23-2016, 04:50 PM | #1 |
Blazer/Suburban Tank in C10
Has anyone mounted a K5 Blazer / Suburban tank under the bed of their truck? I have bought the 31 gallon tank and was just curious what everyone did to route the fill neck. The fill neck on the tank is going to point towards tbe inside of a framerail and offset to one side. It kind of irks my OCD. I would prefer for it to be center.
1964 Coupe Deville(cruiser) 1966 Chevy II Nova 2door Hardtop 1985 C10 LS1/4l80e, Ridetech coilovers,22”Coys 2019 F-250 Platinum-Deleted/Carli Supension 37” MT’s 2000 Trans Am WS6, LS1/T-56, too many mods to list |
12-23-2016, 04:52 PM | #2 |
Re: Blazer/Suburban Tank in C10
12-23-2016, 05:19 PM | #3 |
I mounted one in my 77 k10 short box. I'll be working on the fuel filler in the next week or 2.
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
12-23-2016, 05:52 PM | #4 |
Looks good! How do you plan to route it?
12-24-2016, 01:37 AM | #5 |
Should be able to use the stock Suburban hose and weld in a new filler in the rear fender. Do it right and no one would know or at least catch it right away.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14, |
12-24-2016, 02:24 AM | #6 |
I'll probably cut the neck off the tank so I can route it into the bed
12-24-2016, 10:35 AM | #7 |
Might take a bit of "plumping" and cutting a couple holes with a hole saw, but I would pick up a "fold down" licence plate assembly from a early 70's Chevy full size car and route the filler neck behind that.
12-24-2016, 10:43 AM | #8 |
I have one already on my roll pan but it's going to be quite a bit lower then top of the tank is
12-24-2016, 10:45 AM | #9 |
12-25-2016, 04:39 AM | #10 |
To be honest I'm not sure yet, when I get my box back on I'm just going to figure it out as I do it. I'll use a stock filler on the outside, but I'm pretty sure that the plumbing won't fit between the inner and outer box sides, so I will have to fab up some sort of cover in the box for the fill tube to be at the right angle. I have a feeling that I can make it look ok, but I don't see it filling at full speed. We shall see.
12-28-2016, 08:35 AM | #11 |
With a bit of eyeballing, and measuring, my fuel filler install went well. It ended up being a straight shot to the tank, it looks like it has good fall, so it should fill well.
05-22-2021, 07:45 PM | #12 |
But Found Her 25yrs Later!
Old thread, but I'm thinking of using suburban tank I have in my 65 C10. If it could be done, I would like to run the filler out on the driver's side.
. I guess one of my concerns has always been the exhaust pipe in proximity to the tank.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 05-22-2021 at 07:55 PM. |
