Old 12-26-2016, 10:41 PM   #1
bL.A.zer90045
truck floor in a jimmy???
im needing to replace a complete frontal floor area in one of my 69 jimmy's and would like to run a bench seat in it.with this said will a 67-72 repop TRUCK floor fit in the jimmy? as to retain the truck bench seat track bolt holes
bL.A.zer90045 is offline   Reply With Quote
Old 12-27-2016, 12:39 AM   #2
harrisoncole4
harrisoncole4's Avatar
Re: truck floor in a jimmy???
I would be interested in a similar setup. Curious what everyone has to say.
harrisoncole4 is offline   Reply With Quote
Old 12-27-2016, 10:04 AM   #3
David623
I bought the floor pan and installed it, I used the body mount holes to help the line up and determine where to cut and and fold up to the knee wall. Where the gas tank would sit is what gets cut off. I don't see why a bench can't be installed unless the floor shifter be a problem.
David623 is offline   Reply With Quote
Old 12-27-2016, 01:25 PM   #4
bL.A.zer90045
What we wanted to hear any recommandations on pan? Also gonna be replacing rear floor,would it be wiser to remove both quarters first? Also I'm looking to swap my drivetrain out of my 92 4x Yukon.
Old 12-27-2016, 04:05 PM   #5
David623
I made up a jig that was corresponding to the body and back bed mounts from the frame. when I reassembled and transferred over to the 72 Jimmy frame it fit like a glove.
Old 12-27-2016, 07:24 PM   #6
69-72
69-72's Avatar
The floors are the same as a truck. I cut the roof off of a pickup cab and made a body for my jimmy from it. I'm not positive but I would doubt the repro floor would have the attachment points for either a bench or buckets already drilled and installed so you would need to do that stuff anyways. Another consideration is the trans hump cover if it's a 4x4.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 01-04-2017, 11:50 PM   #7
ktonthemove
The repro floor pan that I got from Car and Truck Shop in Orange, CA had a low rise hump. They said most repro's come in the low hump and it's another mod to make on the floor if you have a 4x4.
ktonthemove is offline   Reply With Quote
Old 01-05-2017, 01:10 AM   #8
bL.A.zer90045
not following on the trans hump cover? my jimmy is 4wd and i have the bolt in cover? would this interfere with the bench? or?
Old 01-05-2017, 01:59 AM   #9
ktonthemove
You'd probably have to cut out a hole in the new pan and then fit your old trans cover to it. And I don't think it would interfere with the bench. I've seen a few 4x4s with bench seats and the clearance looks just fine. Might be a different story if you're running a manual transmission.
