12-29-2016, 09:31 PM | #1 |
MSD 8362 Distributor
I was thinking of installing this distributor in my 72 K5. Will it fit?
1972 cheverolet K5 CST Blazer 350/auto/AC/PS/PB/Aux Batt From Medford, Oregon |
12-30-2016, 01:22 PM | #2 |
Re: MSD 8362 Distributor
It should. Its a tight fit. When installing you'll have to take the cap off...
12-30-2016, 02:49 PM | #3 |
back when I used to use a dist. per se, the coil in cap was tight, like 1/2" - 3/4" tight. That was a coil in cap type like yours. You would be better off if you used a small cap with a separate coil mounted elsewhere
JMHO, but if there was any engine shift you will break the cap, and leave you stranded. This is on an off-road condition
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
01-01-2017, 09:58 AM | #4 |
Thanks for the replies. I will find out soon enough. I ordered my 1978 corvette spark plug wires today. As soon as I get them I will make the swap.
