12-31-2016, 09:56 AM | #1 |
Transfer Case Shifter Wobble
I have a 72 Jimmy and the transfer case shifter wobbles side-to-side.
Presumably there should be a spring or something to keep it stable. Can anyone tell me what should be there and if possible post a photo? Thanks! |
12-31-2016, 11:11 AM | #2 |
Re: Transfer Case Shifter Wobble
No spring.your bolt and or shifter is just worn. If its lifted your driveshaft
Angle could be wrong causing it to vibtate. |
12-31-2016, 05:25 PM | #3 |
[url=https://flic.kr/p/QpsjkW]
It is only held in place with a large pivot bolt, maybe your bolt is backing out, can't imagine shifter bolt or shifters wearing into an egg shape to allow wobble, but these trucks are over 45 years old. Lack of grease could cause it [url=https://flic.kr/p/P9qons]
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-31-2016 at 05:33 PM. |
01-01-2017, 09:47 AM | #4 |
I had one do that about 20 yrs ago, and I put large plastic washers from a plumbing supply between the bolt and divorce mount and worked great. Mine was a chinging and a rattling too.
01-01-2017, 01:36 PM | #5 |
Thank you for all the info and photos!
I will have a closer look and try to source a new bolt. I love this forum! |
01-01-2017, 04:06 PM | #6 |
I worked on my 70 Blazer NP205 a while ago and learned there were 2 size bolts used over the years. In my case I needed the narrower 7/16-14 thread bolt.
1969-70 used 7/16-14 x 2-3/4 bolt with 5/8 head 1971-72 used 9/16-12 x 2-3/4 bolt with 15/16 head - the pic above from jaros44sr is it. - I may have one, shout if you want me to look, they usually go for around $50 -Jim |
01-02-2017, 08:31 AM | #7 |
69 and 70 utilized the 221 case and in 1971 they went to the 205
01-02-2017, 11:49 AM | #8 |
01-02-2017, 04:11 PM | #9 |
Thanks. I am thinking about maybe going to a dual stick.
I installed a Lokar shifter on the floor and was thinking about making a console - so now would be the time for a twin stick! |
01-02-2017, 06:22 PM | #10 | |
I had the same problem with making the two shifters look right together, and I think your mount for the Lokar may be the answer If you find Stephan Jarvis's number please pm me
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-02-2017 at 06:28 PM. |
01-02-2017, 06:30 PM | #11 |
Sorry - don't have many photos and the truck is tucked away for the winter.
I got the nostalga version of the lokar shifter - it has a funky bend in it! I also got the matching bott trim ring that includes an LED display to show what gear its in. Super easy to install. If I get serious about the twin stick idea I'll pm you. |
01-02-2017, 06:35 PM | #12 | |
It looks like if you move the shifter to the rear mount, both would line up. Am I correct?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
01-02-2017, 06:37 PM | #13 |
Couple more photos of the truck.
01-02-2017, 06:43 PM | #14 |
Jaross44SR - they would be close if you used the rear mount.
I cut about an 1 1/2 inched out of the length of the transfer case shifter to make it sit a little lower and a little more towards the passenger side. I had a B&M pistol grip shifter left over from another project and put it on the transfer case shifter. |
01-02-2017, 06:46 PM | #15 |
Dude, that thing is sweet, you should be out running around in the snow LOL
01-02-2017, 07:26 PM | #16 |
It would be fun in the snow!
Problem is they use a silly amount of salt on the roads up here! |
01-03-2017, 11:05 AM | #17 |
salt sucs, I ride upstate NY, and half the bodies are gone up there, somehow, still passes state inspection
What shifter mount did you buy....trans mount or tail shaft mount?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-17-2017 at 12:17 PM. |
01-03-2017, 11:32 AM | #18 |
I bought the trans mount - I wanted the transmission shifter to sit ahead of the transfer case shifter.
01-03-2017, 03:19 PM | #19 |
01-03-2017, 06:28 PM | #20 |
Didn't see your truck.
I'm in the west end and have only seen 1 blazer, a bright orange 1970. I bought mine from a gentleman in Chicago in 2012. Drove through Oshawa over Christmas - I am originally from Kitchener and drove down to visit. |
01-13-2017, 12:00 PM | #21 | |
My twin stix wobble, and thinking of turning down some sort of plastic, between both shifters, but didn't know if I should put it between all joints Why don't they put the salt away, and let us fend for ourselves
01-13-2017, 12:07 PM | #22 | |
01-15-2017, 08:34 PM | #23 |
Sorry for the delayed response - I have been out of town.
Yes! You have a good eye. In order to get the shifter where I wanted it I cut a slot in rear holes to mount it. |
01-17-2017, 12:16 PM | #24 | |
What happened to cinders or sand for road traction
01-17-2017, 04:41 PM | #25 |
Exactly - bring back sand! And perhaps plough the streets occasionally...
