Old 01-04-2017, 11:57 AM   #1
Scurvy
Scurvy's Avatar
Steering column bracket
I need the steering column bracket that fits under the dash, I have been through manuals and all over the internet. Does anyone have any information??
Scurvy is offline   Reply With Quote
Old 01-04-2017, 01:26 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Steering column bracket
Here you go. A picture of the 3 brackets under the column. thanks to LOCDOC! A junkyard is going to be your best bet though!
The bracket shouldn't be to hard to make. Flat stock wrapped around the column with bolt holes.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-04-2017, 01:39 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Thanks Andy!
The small narrow bracket goes in first and is the one that actually holds the column to the dash. It uses two 5/16 x 1 inch bolts. It is different on the ends so make sure you have it installed correctly. The large one is the pedal stop plate and has two small square holes in it for the pedal bumpers. It uses four 5/16 x 3/4 inch bolts. The fancy one is the trim plate for the gap between the column and dash. It fits over the rubber gasket. It has two #8 or #10 (can't remember for sure) x 3/4 pan head sheet metal screws....
Like Andy said, salvage yard if you have any close. If not check on the parts board on here. Anyone that parts trucks on there will have what you need.
LockDoc
Leon
Old 01-04-2017, 03:11 PM   #4
Scurvy
Scurvy's Avatar
Originally Posted by LockDoc View Post
Thanks Andy!
LockDoc
Old 01-04-2017, 03:12 PM   #5
Scurvy
Scurvy's Avatar
Thanks for the prompt reply!!
Old 01-04-2017, 03:33 PM   #6
biketopia
I might have those pieces in my stash of parts
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is online now   Reply With Quote
Old 01-04-2017, 03:49 PM   #7
El Dorado Jim
try a wrecking yard, if no luck I may have what you need,do you need all 3 parts?
El Dorado Jim is offline   Reply With Quote
Old 01-04-2017, 05:04 PM   #8
Scurvy
Scurvy's Avatar
Please check, Ill take em if you got em.
Old 01-04-2017, 07:08 PM   #9
El Dorado Jim
do you need all three pieces? I have all three
Old 01-04-2017, 07:26 PM   #10
Scurvy
Scurvy's Avatar
Yes please.
Old 01-04-2017, 10:27 PM   #11
El Dorado Jim
Yes please.
I will check and see how much shipping is to Bakersfield, you have the bracket that bolts to the firewall on the engine side?
Old 01-04-2017, 10:34 PM   #12
Scurvy
Scurvy's Avatar
that's the only one I have. What other stuff do you have??
Old 01-04-2017, 10:43 PM   #13
El Dorado Jim
I parted out a truck years ago and have some interior stuff, what do you need...my wife says it will cost around $13.00 to ship it to you, I only want the cost of shipping, send me $15.00 and we will call it good, pm me and i will get your name and address, and you mine
Old 01-04-2017, 11:04 PM   #14
El Dorado Jim
pm 'ed you back
Old 01-05-2017, 03:43 PM   #15
El Dorado Jim
Hey Scurvy, since you are a new member here, not sure if you know about lmc truck and truckandcarshops, good places to buy aftermarket parts, there are others also. http://www.lmctruck.com/chevrolet/ http://www.truckandcarshop.com/6072.html
Old 03-28-2017, 08:36 PM   #16
Mhussnatter
Sorry to revive this old thread from back in January but I am in need of these parts. I have a 1969 C10 and The previous owner of my truck ripped out all of the steering column brackets and jammed a mid 80's van column in the truck and rigged it up bad. I have taken it out and installed an IDIDIT column but unfortunately can not mount it at the dash because everything is missing. I have been searching vendor websites and can not find these parts can anyone point me in the right direction?
Mhussnatter is offline   Reply With Quote
Old 03-30-2017, 01:55 AM   #17
El Dorado Jim
wrecking yards are your best bet or check the parts for sale board on this site,I dont think I have any more of these parts,but Im going to pick n pull Friday,will take a look for you
Old 03-30-2017, 07:32 PM   #18
Mhussnatter
El Dorada Jim Thanks buddy I truly wish it were that easy but unfortunately for me there are NO salvage yards at all where I live. There are a couple just over an hour or so away but none of them have any 67-72 trucks
Old 03-31-2017, 12:35 AM   #19
El Dorado Jim
I went to four pick n pulls today instead of tomorrow and not one 67-72 truck at any of them....I have a business card of a guy in Sacramento that parts these old trucks out, I will look for it tomorrow and give you his name and number...he will definitely have the parts you need...Jim
Old 04-01-2017, 02:24 AM   #20
El Dorado Jim
didnt have time today to look, will look tomorrow for the number of the guy in Sac that has the parts..
Old 04-01-2017, 07:05 AM   #21
Mhussnatter
Thanks anyway Jim but I got what I need now. One of the other members was able to find for me at a salvage yard. Thanks
Old 10-15-2022, 03:56 PM   #22
Gib74
Bringing back an oldie post. Any chance anyone has the halfmoon clamp? This is the clamp on the left in Andy4639 picture. Thanks guys and I'm a newbie first time poster as well.
Gib74 is offline   Reply With Quote
Old 10-15-2022, 05:58 PM   #23
Jason Banks
Jason Banks's Avatar
I'm sure the moderators will be along to tell you, you need to be a supporting member to post a WTB (want to buy). To become a supporting member there's a link at the top of the page that says "Subscribe" it takes you to: https://67-72chevytrucks.com/vboard/payments.php
Back to your question. I would call Bill and see if he has one - https://www.facebook.com/ChevymanBill/
Or Tremayne
https://www.facebook.com/people/Trem...0057753605935/
Jason Banks is online now   Reply With Quote
steering column, steering column bracket
