Old 01-04-2017, 10:52 PM   #1
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Flat Out C4 Install Instructions
Looking for a set of the Flat Out C4 install instructions for the rear suspension. I can't find mine anywhere. Thanks for the help guys.
--Josh
Old 01-05-2017, 12:23 AM   #2
svr
svr's Avatar
Re: Flat Out C4 Install Instructions
If you scare up a set i would like a copy also, mines a TF so would be different probably. Do you have plans and specs for the front you built? I could sure use a copy of the front also. Have the equip and know how but hate to waist a bunch of time andmaterials trying to figure it out. Any help would be appreciated, thanks
svr is offline   Reply With Quote
Old 01-05-2017, 09:01 AM   #3
mongocanfly
Post Whore
mongocanfly's Avatar
Just contact Don at flatout..he's very helpful and I'm sure he'd shoot you a copy
Old 01-06-2017, 07:22 PM   #4
4544speed
4544speed's Avatar
He would not furnish them to me before I purchased my kit. I wanted to see how good the directions were and get an over view. IM me for more info.
4544speed is offline   Reply With Quote
Old 01-07-2017, 12:33 PM   #5
58CameoAZ
I know i have my front IFS instructions as i was looking for them the other day, but
Dang'd if i could not find the rear Instructions. I will tell you the rear was pretty much detailed with drawings, But the front could of been better as they were a little vague,
do a search as there is someone with an article on installing their kit and shows some better detail when you go to install, also i used the Aldan Coil overs and he shows a detail on putting a relief in the frame at the top, as the coils just touch the frame at their mounting point. If i can find it i will pass it along to you, All in all i am very happy tho with the Flat Out Kit and when i called them they were very helpful to me!
Good luck with your build,
Allen
58CameoAZ is offline   Reply With Quote
Old 01-08-2017, 01:14 AM   #6
Az. Hank
Az. Hank's Avatar
I've got them at home for a Task Force but I'm nowhere near home.
My 55 Build 55 C-4
Az. Hank is offline   Reply With Quote
