01-10-2017, 11:15 AM | #1 |
wilwood master cylinder?
they have the tandem master cyl on sale and I,ve been wanting to change my78 from power to manual.they have a 1 in.and a 1,125 in bore.I can,t afford hydroboost but my other truck has manual brakes and stops just as good.Is wilwood a good choice.
01-11-2017, 03:32 AM | #2 |
Re: wilwood master cylinder?
Wilwood is great if you order the right bore size.I would talk to wilwood they will know which size you need.
01-11-2017, 08:23 AM | #3 |
67-72 parts collector,…
Wilwood recommends 7/8" or 1" bore for manual brakes.
Its on their website. http://www.wilwood.com/MasterCylinde...temno=260-8555 QUOTE: Wilwood’s Tandem Aluminum Master Cylinder is available in 2 bore sizes 1.00” and 1-1/8”; and 3 finishes, plain, ball burnished and black e-coat. 7/8” bore master cylinders are designed primarily for manual applications and include a pushrod. The 1” bore can be used in manual and power assisted applications and does not come with a pushrod. The 1-1/8” bore is designed for use primarily with power brake applications, either from vacuum assist or hydraulic assist systems. They’re designed for mount flanges from 3.22” to 3.40”, common measurements for most domestic cars and trucks from the mid 1960s to present, and offer fluid outlet ports on both sides of the bore. The stroke is set at 1.10” with a volume ratio of 2:1 between the primary and secondary chambers. Machined from high-pressure die castings, each master cylinder weighs only 3lbs, a 75% weight savings over most cast iron OE type master cylinders. We also offer a our combination proportioning valve kit, which includes brackets and stainless lines specifically for use with these master cylinders, see PN 260-13190, or 220-13189 for retrofit kit.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-11-2017 at 08:57 AM. |
01-11-2017, 09:31 AM | #4 |
do you think I need a proportioning valve ? no track racing on this,just a weekend cruiser
01-11-2017, 11:06 AM | #5 |
yes
01-11-2017, 11:34 AM | #6 |
FYI the summit brand adjustable proportioning valve is made by wilwood, and is only like 20 bucks.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
01-12-2017, 10:17 AM | #7 |
ok thanks
