My contribution to a better society
I am having major issues trying to upload photos. I am trying to get away from Photobucket and use Google drive. There wasn't a way to run a test post so bare with me while I figure it out. In the mean time, if you use Google drive and know how to post an embedded pic please hit me up via call or text 610-256-1638
I am going on the fun. Rather than see this truck go to waste I picked it up for a build. Barely ran, barely stopped, barely working in general really. More coming test post, if you read this I am editing right now please don't post. Last edited by keystoneGerm; 01-17-2017 at 09:42 PM. |
Re: My contribution to a better society
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
Thanks for the help. I can't edit the second post now. Never had that problem in other forums.
So, the plans for this truck: 3/5 drop with flip, Red metallic paint with new black interior Full brake revamp All new suspension and steering 87+ 350 with headers, Summit 1065 cam Summit intake manifold and Edelbrock 600 carb Just trying to build a normal daily driver that is really nice.it needs a decent amount of body work, but overall isn't too bad. I am looking to buy an extra cab to do the body work off the frame. I will have an extra title and VIN plate if anyone e needs one, hit me up. More pics to follow. I already did all the brake work and the steering and suspension is already ordered along with all the engine parts. |
#5 | |
I have settled on Photobucket for all my forums. I have several hobbies.
![]() Looks like a good start and a good plan for your truck.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
[IMG]
![]() Got the engine in last night. Still have a lot to go before I get it running. I am trying to decide on interior. I have been all over reading reviews of dash pads. For every good review of one there is another bad one. I want one that looks nice. It seems that most have issues with cluster fitments. I dont care about trimming stuff, but I want it to look good when done. I was thinking about starting a new thread for just dash pads where people can post pics, prices, part numbers and dates they bought them. Try to make a all inclusive style post. What do you guys think? |
Following along and glad I did. I've had some a/c vibration issues on the Suburban and just noticed from your photo that it's missing the brace that goes from the bracket to the side of the manifold.
I'd be interested in a dash pad thread.
Romans 10:9 - The Truth |
![]() Join Date: Jul 2000
So, tell us about the engine. Did it start life as that TPI engine in your truck bed?
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 01-22-2017 at 12:52 PM. |
Well, story goes as it was in an 86 IROC Z. The car was disassembled in 97 and the engine was put in dry storage. The car had 66k on it. I did some research and the 5.7 was not offered in 86. So the guy I got it from said, "Maybe it was an 87?". Regardless, it is definitely an 87+ 350. When I pulled the TPI manifold off, I found that they slotted the middle bolts for the different angle. So in fact it was an 86 IROC that had a newer 350 in it. So unfortunately, I do not know the mileage on this one, but it was really clean, and had the letters "CFE" stamped in all 4 corners of the heads. So it was either rebuilt or a savage yard engine. I am leaning towards rebuilt due to not having any temp indicators glued to any freeze plugs or heads.
Specs now are summit dual plane manifold, Edelbrock 1406 carb, summit 1065 cam and new lifters with a new true roller timing chain. The engine has been resealed, cleaned and painted with a single stage urethane in semigloss black. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() These headers fit really well. They were removed from a c10, but wasn't sure what they were made for. I didn't want to run the hedman for our trucks because they hang too low for a slammed truck. I didn't want to give up the HP from a set of shorty's, so I am going to notch the cross member a bit on the P/S and the driver's side I can weld the exhaust at a slight angle to fit above the cross member. I had to make a bushing for the A/C bracket so all day today was project headers. Next on the menu is the carb linkage and then onto the exhaust. |
#13 |
Cool truck and I will be watching.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#14 |
Thanks. You guys are the greatest.
#15 | |
Hedman 18803: ![]() ![]()
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#16 |
That is really good info. Thanks for the help
#17 |
FYI, I used 2 coats of VHT high-temp paint over 2 coats of this KBC 1200 degree primer. After 3 months of the truck sitting outside, there are no signs yet of any rust. Much better than using just VHT paint. Turns out the Hedman extensions aren't aluminized, so I need to coat them, too. For your headers, I'd suggest using some type of rust converter before painting.
https://www.kbs-coatings.com/XTC-Primer.html ![]()
#18 |
I have never seen header paint last, so I wasn't going to waste my time. If you get yours up and running let me know or I will contact you to see how it's lasting. When I pull the cab and front clip, I'll repaint if you still have good results.
#19 |
#20 |
Got the exhaust done today. I am pretty happy with the Pypes dual exhaust system. One bend wasn't right, but I was planning on welding most of it together anyway. I had to do a few pie cuts to clear the driver's side crossmember, but not to bad.
This is what I started with. ![]() First side done, no progress pics though. ![]() Then made a few cuts with the torch ![]() ![]() ![]() Welded the system together. ![]() Got it on, sucks I couldn't get the X-pipe centered ![]() Giving myself plenty of room in case I C-notch it later. ![]() |
#21 |
Worked on the harness today. All day spent on just the A/C portion. I rerouted under the air box, reloomed with nice loom and heat shrink all ends. Got rid of the junction block on the firewall, so ran my last fuse off the alternator. Now I am working on the transmission wiring for the kickdown and torque converter lockup. Anyone know what the red 2 wire plug is for the transmission?
These connectors are awesome to depin to do the wiring reloom. I am used to garbage Volkswagen pins that get stuck on the reg. ![]() ![]() ![]() |
#22 |
I used this diagram to figure out my lockup. Thanks to another member here on the board, and Google images. I fully deleted the ECS distributor wiring.
![]() I got the rest of the harness roughed in. This one is going to be a ***** to loom. Fuses are already connected and can't depin, the oil pressure switch and sender can't be depinned. I may cut and resolder to get the heatshrink on at the same time extend or shorten as needed. ![]() Time for bed. |
#23 |
Making pretty good process. Got the distributor in and am making the wires today. I think I can have it running tomorrow. Need to run a wire to the fuel pump and finish plumbing in the pump and filter. Install radiator and fluids.
On a side note. I think I am buying ab 81 C60. I am going to use the doors off of it and the 22' box. I will be selling the truck complete of part out. I live in a nice neighborhood and can't have the truck sit here. If you need something, LMK. It's a 366 with a 5 speed. |
