01-22-2017, 04:42 PM | #1 |
1970 Vin Plate location
Could someone take some measurements of where the holes for the vin plate on a 1970 pickup should be? I just need the position down from the latch indentation.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
01-22-2017, 05:23 PM | #2 |
Re: 1970 Vin Plate location
I get 9 3/4" from center of outer lower latch bolt hole to center of outer upper VIN-plate rivet
01-22-2017, 05:42 PM | #3 |
Thanks, is that a 71 or 72 you measured? The vin plate for a 70 is higher up than a 71 or 72
01-22-2017, 07:08 PM | #4 |
Yes, I did measure my '72. I never thought about that. I guess the jamb vent makes 71-
/72s lower. I just checked a cab I have but it looks like it's a '69. Sorry for giving bad info.
01-22-2017, 07:29 PM | #5 |
I measured 1-7/16" from the edge of the latch indentation down to the center of the left rivet
1970 C10 Short Stepper with 71/72 front clip. |
01-22-2017, 08:41 PM | #6 |
Awesome! Thanks
01-23-2017, 09:33 PM | #7 |
Active Member
If you take the vin plate off for paint where do you find those funny rivets to
replace it?
cascadeheavychevy 67 C10 327 4speed 69 C20 350 4WD 4speed 69 C20 350 4WD 4speed 69 C20 350 4 soeed 69 C20 CST 350 Auto 70 C10 307 4speed 71 GMC Supr 350 Auto 70 C10 350 Auto 67 CST 327 Auto |
01-23-2017, 09:43 PM | #8 | |
And they are commonly referred to as rosette rivets.
01-24-2017, 12:24 AM | #9 |
11-14-2017, 09:54 PM | #10 |
Where are the VIN locations? I tried to register my vehicle today at DMV and was told I needed to have 2 VIN locations. I could only find the VIN plate on the door...
1970 GMC Jimmy LT1 w/Holly EFI Willwood Hydroboost |
11-14-2017, 10:45 PM | #11 |
There are 2 full VINs: metal tag and SPID in the glovebox. There is a partial VIN on the frame rail topside in the vicinity of the steering box.
EDIT: Would use the partial frame VIN only if the SPID didn't exist or the gb door had been changed. Also - actually check the frame VIN first if you're gonna let them see it - might be embarrassing if you learned you had a cab or frame swap in front of the little ol DMV lady. |
