02-03-2017, 08:35 PM | #1 |
Old member
Swapping wipe switch
I installed the new to me tach dash today in the 68 cab. The old cluster had the head lights and wiper on the left side both. The new cluster had the wipers on the right hand side.
So I had to lengthen the wires going to the switch to let it reach to the other side. No biggie! Just took a bit longer. I also had to notch the upper dash hole for the head light switch. I installed the new dash pad as well.
02-09-2017, 03:01 AM | #2 |
Re: Swapping wipe switch
Looks great. Its nice to do a mod and have it turn out nice.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
02-09-2017, 04:04 AM | #3 |
nice tach dash!!!
02-09-2017, 05:30 AM | #4 |
I've thought of doing the same only opposite and moving the Wiper Washers over to the left, above the Headlight switch, so I could add a manual Throttle knob above my manual Choke on my '71 GMC.
Heck, I could even swap in a 16.5" - '68 3-spoke wheel for the 17" - '71 2-spoke wheel and confound the gullible that my Jimmy is an experimental GMC K/750 from 1968. Wouldn't fool you guys though.
02-09-2017, 08:59 AM | #5 | |
Old member
It may fool some. I have seen all kinds of dashes and arrangements. The only reason I swapped it was the tach dash was for a 71-72 truck, the other was for the 67-69. + I'm use to my 71 dash also and I caught myself reaching up to turn the wipers on with my right hand all the time.
02-09-2017, 02:55 PM | #6 | |
OR ?
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 02-10-2017 at 02:38 AM. Reason: correction |
02-09-2017, 06:50 PM | #7 | |
Old member
02-10-2017, 09:53 PM | #8 |
Old member
Went today and picked up some rear window squirters off of late model Envoys.
Tahoe's, Suburbans and anything else with rear washer should work.
02-10-2017, 10:17 PM | #9 |
Hmm. Gee Andy, whatcha gonna do with them?
[I meant to say the headlights were always on the Left.]
02-10-2017, 10:22 PM | #10 | |
Old member
The squirters will go on the wiper arm to spray the whole swipe when the wiper is moving. It will clean the window better. I have them on my 71 also and they work much better than a straight stream.
02-11-2017, 06:47 PM | #11 |
I like that gag. Show us more.
Neither of my 2 runners ['68 Stepside, and '71 Jimmy] have operating swisher/sloshers. I usually just splash a half gallon of water from an old antifreeze jug and run the wipers full blast. Cannot access during running in traffic.
02-11-2017, 08:07 PM | #12 | |
Old member
I put one in my 71 and it works good. I already have the electric jug in the Ramp truck but didn't get any nozzles. I just picked them up this weekend. First 2 pictures are the 71 mod. 3 picture is the jug in the ramp truck. Hopefully tomorrow I get enough time to hook the nozzles up on the Ramp Rat!
02-12-2017, 01:22 AM | #13 |
What's the washer fluid jug in the Red truck from?
About 12 years ago,I tried rebuilding the OEM washer squirter assembly from a Checker Auto kit. Total PIA, and then it didn't work. So back to cave splashing with the gallon jugs. I like your system.
02-12-2017, 10:26 AM | #14 | |
Old member
The washer motor you hook straight to 12v then run a ground to the switch on the dash. Piture for hook up.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 02-12-2017 at 10:32 AM. |
02-12-2017, 01:58 PM | #15 | |
Tubing runs directly to squirters? Do I bypass the old in-cowl jets? Mine are clogged anyway.
02-12-2017, 07:43 PM | #16 | |
Old member
I just finished hooking up the squriters on the Ramp truck and to be honest not to impressed with them as they don't spray like I thought they would. They will do for now though. I'll be looking for some others though. I also got all my seat belts installed and the passenger side mirror fixed and installed.
