Old 02-11-2017, 11:37 AM   #1
master 1969 c10
Active Member
Flywheel cover doesn't fit
I I have a Chevy Turbo 400 modulator is in the back of transmission and transmission pan is the shape of 400 pan. I bought aluminum one about 5 years ago and the holes don't line up the holes the holes close to the transmission is 10 inches Center to Center and I took the cover to jegs and the one the had came up the same measurement of the one I have so it doesn't fit either and there is no spacer adapter on the transmission the bellhousing is a direct bolt-on to the motor has anybody else ran into this problem did one or two years of the Turbo 400 have a larger flywheel pan bolt pattern. My truck is coming along but it seems like I take one step forward two steps back. The top holes are about 1/2 inches off needs to be longer. Thanks Doug
master 1969 c10 is offline   Reply With Quote
Old 02-11-2017, 11:49 AM   #2
B. W.
B. W.'s Avatar
Re: Flywheel cover doesn't fit
Post some pics if you can.
B. W. is offline   Reply With Quote
Old 02-11-2017, 12:13 PM   #3
geezer#99
geezer#99's Avatar
X2 on pics!
Turbo 400 has modulator on the side.
Old 02-11-2017, 09:56 PM   #4
master 1969 c10
Active Member
Pictures
Old 02-11-2017, 11:25 PM   #5
geezer#99
geezer#99's Avatar
So, your modulator is on the side like a turbo 400.
I found a designation for a 3L80 tranny of 1990 and up vintage.
Perhaps the tranny is from a hd motor.
Does the cover you have fit except for the bolt holes?
Old 02-11-2017, 11:42 PM   #6
master 1969 c10
Active Member
Yes, it fits. The Cover just needs to be a like 3/8 longer or so
Old 02-11-2017, 11:46 PM   #7
geezer#99
geezer#99's Avatar
Which holes aren't close?
Are you adverse to drilling and tapping new holes.
Old 02-12-2017, 12:34 AM   #8
100%Chevy
There are at least 2 different T-400 flywheel dust covers.
1 for the small block engines and 1 for the bigblock engines.
Do you have a big block engine?
The difference in the covers is where it goes on the rear main of the oil pan.
A smallblock cover on a big block will be about 3/8" too short to fit right.
May be you're problem.
Mike.
100%Chevy is offline   Reply With Quote
Old 02-12-2017, 11:05 AM   #9
master 1969 c10
Active Member
Thanks for all the help. I have a chevy sbc 350 for the motor . And all the holes don't line up.
