Old 02-13-2017, 03:23 PM   #1
LSSierra
87' LS Swap fuel system
I'm sure this has been asked but because of the volume of threads on here I can't seem to find what I'm looking for with what I'm working with. Have an 87' Sierra, fuel injected 305 I'm yanking out and putting in a 5.3 LS with 4l60 tranny. I'm determined (cause it's cool and it currently works) to keep my dual fuel tanks working when the swap is complete. I've heard a myriad of things about how to do this. I have a returnless system, truck intake. Can I use the stock fuel lines and just get new fittings for the new pumps and corvette regulator or do I need to replace all fuel lines? Basically, can someone who knows this well help me out from the tank all the way forward to the intake? My buddy used this site for his build and I've learned a lot. Thanks in advance guys!!
LSSierra is offline   Reply With Quote
Old 02-14-2017, 04:01 PM   #2
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: 87' LS Swap fuel system
Look at this thread (its long, but VERY informative). I believe he did the dual tank set up on this one.
http://67-72chevytrucks.com/vboard/s...d.php?t=350986
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-14-2017, 04:02 PM   #3
aggie91
aggie91's Avatar
Look at POSTS #7 & 8 of this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=674371
Karl
The LST Challenge:
Old 02-14-2017, 07:27 PM   #4
LSSierra
Thanks Karl I'll check it out!
-1987 GMC Sierra Classic 5.3 LS -
-2001 Toyota Camry 175k -
Old 02-14-2017, 09:56 PM   #5
LSSierra
Ok let's see if I have this right:
Replace my 87 stock fuel pumps in the tank with the AC Delco pumps using same connectors and plugs for wiring, then moving out of the tank replace all lines not metal, then replace the tank selector to a higher capacity so I don't blow that, then use existing metal lines that already go into the engine bay and go into the corvette regulator (mine isnreturnless) and plug the return line and go from the regulator to my fuel rails. Sounds simple...can it be that easy since I'm already set up for FI or do I need to change all my lines and fittings since it's higher pressure?
Old 02-15-2017, 10:23 AM   #6
aggie91
aggie91's Avatar
You have it correct. You still need the return line as it comes out of the vette filter/regulator to go back to the tank. The steel lines in your '87 are more that capable for the 58 psi that the LS engine uses.
It really is that simple...
Karl
The LST Challenge:
Old 02-15-2017, 03:31 PM   #7
LSSierra
Thanks so much Karl...huge help knowing I'm not off my rocker here...and pretty excited I don't have to run all that line!!
Thanks for taking the time.
dman82
