Old 02-18-2017, 09:23 PM   #1
logansdad
logansdad's Avatar
Project Cheyclone
So here it goes... another crazy idea I've had in my head for a while now. What would happen if you just so happens to have a 1991 syclone just sitting around for the past 20 years with a rebuilt title and a bent frame with only 29k miles. And a couple of square body c10's. You make a Cheyenne Syclone or a "Cheyclone".
No it won't be awd. But it will be very different from anything else. V6 turbo with 400 transmission and gear vendor. Pro touring suspension with coilovers. And yes I'm keeping the syclone seats because they are just that cool... bring on the ideas and comments!
1972 chevy sububan----frame off restoration now for sale😟
http://67-72chevytrucks.com/vboard/s...d.php?t=560803
1968 GMC Suburban- turned 67 air ride, streched and shaved everything, 22" detroit steelies, lt1 http://67-72chevytrucks.com/vboard/s...d.php?t=668574 suburban 4x4 1 ton zz454 daily kid hauler
1991 gmc syclone
1987 c10 silverado
"Hey lifted 4x4 guy does your truck know what mud is"
"Every inch you go up is an inch you don't have"
logansdad is offline   Reply With Quote
Old 02-18-2017, 10:14 PM   #2
91short
Re: Project Cheyclone
I've always wondered how the syclone engine would push a full size truck around.
91short is offline   Reply With Quote
Old 02-18-2017, 11:02 PM   #3
dragonball98312
dragonball98312's Avatar
Will you be parting the syclone!? Curious how well a turbo 4.3 will be in a full size
dragonball98312 is offline   Reply With Quote
Old 02-18-2017, 11:36 PM   #4
logansdad
logansdad's Avatar
Yes I'll be parting it out I'll post the stuff here in classifieds and eBay. This syclone has been in the family most of its life and I have an old time slip for 10.49 in then1/4. I know what mods it had but I'm personally shooting for 600 hp. The c10 should be close to the same weight within a couple hundred pounds. And having 6 speeds should make the go fast pedal fun
1991 gmc syclone
1987 c10 silverado
Old 02-18-2017, 11:57 PM   #5
Ziegelsteinfaust
I have driven a 1992 4.3 gmt400 truck, and a 2012 Chevy work van with the 4.3. both of which would be heavier then a rcsb square body.
If you were putting along both felt like yes it has some power. Then you put your foot down, and the let down began. These were 100% stock, and I have heard with full bolt ones they work very well for DD.
So I imagine a turbo with a decent gear set would be pretty awesome even if boost was kept low.
Why not use a built 4L65E? It would give better control of the torque converter, and likely give an edge in hwy mpg. If that is important to you.
Ziegelsteinfaust is offline   Reply With Quote
Old 02-19-2017, 08:49 AM   #6
logansdad
logansdad's Avatar
400 with a gear vendor is now a six speed transmission with a taller top gear. On the plus side it won't break with abuse of 600 hp
1991 gmc syclone
1987 c10 silverado
Old 02-19-2017, 11:53 AM   #7
logansdad
logansdad's Avatar
Seats and engine bay
1991 gmc syclone
1987 c10 silverado
Old 02-19-2017, 03:07 PM   #8
Omegadog
Omegadog's Avatar
I drive an Express 2500 van for work that's full of service parts etc. and with the 4.3L Vortec and it doesn't feel like it's even trying at 65-70 mph. It amazes me that 600 ponies can be had with a V6. Have fun with your interesting build. Subscribed.
Rock and roll and Chevrolets...what more need I say?!
My '84 Silverado build progress...
https://www.flickr.com/photos/99009428@N08/
Omegadog is offline   Reply With Quote
Old 02-20-2017, 08:56 PM   #9
rusty76
rusty76's Avatar
I am going to have to watch this.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 02-20-2017, 09:19 PM   #10
dragonball98312
Ive always wanted a syclone body kit for my 89. If you sell any pieces youll make a ton
Old 02-22-2017, 12:15 PM   #11
JohnJ@RideTech
JohnJ@RideTech's Avatar
Man, I really want that Syclone..
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 02-22-2017, 01:45 PM   #12
daddyjeep
daddyjeep's Avatar
I have to say that I am a little disappointed that you are not doing awd. It will still be cool though. I know that there is a lot of potential for the 4.3. I was building one for my s-10 years ago and found a lot of internal goodies at race car swap meets. A lot of lower level circle track series ran those motors.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 02-22-2017, 05:17 PM   #13
logansdad
logansdad's Avatar
The thought is still haunting me about the awd... going into that on fullsize requires a lot of engineering to get the correct stance. It would be cool and different, but so is this build anyway. I've considered trying to find a ss silverado wrecked and use the suspension from that and incorporated to the square body
1991 gmc syclone
1987 c10 silverado
Old 02-22-2017, 05:23 PM   #14
logansdad
logansdad's Avatar
I really want a four link rear end with coilovers and tube a arms with rack and pinion front with coilovers. What can ridetech do for the square bodies
1991 gmc syclone
1987 c10 silverado
Old 02-24-2017, 08:14 AM   #15
LT7A
Very interested to watch this. Always thought some engineer/hotrodder must have forged some signatures and pushed the Syclone/Typhoon through while the GM mgmt execs were at a management retreat or something. Any thought about building this in stages? Maybe hold onto the transfer case for stage 2 being awd. Stage 3 with a six-speed you-choose transmission (lose some weight and drive-train friction losses). Stage 4 with an independent rear suspension. Disregard my ideas if you like, it's all good to me. Just got me thinking. Whatever you do, this'll be cool.
Old 02-24-2017, 09:39 AM   #16
logansdad
logansdad's Avatar
I love the ideas keep them coming.🤔
1991 gmc syclone
1987 c10 silverado
Old 02-24-2017, 01:27 PM   #17
daddyjeep
daddyjeep's Avatar
Sounds like a good plan to me. Corvette rear.
04 1500 crew cab
Old 02-24-2017, 01:38 PM   #18
Throckmorton Whump
Usually a lurker, but can't not comment on this one LOL
I love a square as much as the next guy, but in order to keep the AWD, I would start with '88-'98 short box single cab 4WD. The drivetrain would drop right into place. Not totally necessary, but I would convert to coilovers in the front to get the stance. Could also stay leafs in the back, but 4 link with coilovers would be cooler. Although not as cool as a Corvette IRS conversion. Dang - add another project to my bucket list.
Have fun, will be watching any way you go.
Throckmorton Whump is offline   Reply With Quote
Old 02-24-2017, 05:24 PM   #19
JohnJ@RideTech
We actually have a brand new Square Body StreetGrip kit that we just released earlier part of last week. Its pretty freakin sweet. Check out the link below and let me know what you think.
http://www.ridetech.com/info/2017/02...etgrip-system/
John J.
Sales/Tech
syclone
