02-26-2017, 07:24 PM | #1 |
BMW & ASE Master Certified
brake booster vacuumm question
Is there any specific location for the port on the intake manifold for a vacuum source for the vacuum assist brake booster? Most common is in the rear most likely to reduce the cost of hose to connect the two.
But does it matter where in the manifold as long as its after the throttle body blade and in the main section of intake, ie, not in an intake runner? I don't have a gen3 manifold to see if the brake booster port just "taps into" the "reservoir of vacuum" aka intake manifold of there's some nonsense around it. I know its not centered and could also be that away to save on the cost of hose?? Thanks, clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
02-27-2017, 07:40 PM | #2 |
Active Member
Re: brake booster vacuumm question
I'm pretty sure the vacuum hose to the booster location is more of a convenience and intrusiveness factor than cost factor. A few inches of vacuum hose would cost pennies and wouldn't make a dent on the cost of the car. But to answer your question, any full manifold vacuum source will do as you mentioned. Just need to find the most convenient, least intrusive location on the manifold that works for you.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
02-28-2017, 03:48 AM | #3 | |
Machining and tapping an iron intake cost tons more than drilling alum base plate and a pressed in barb. And yes any place in the intake ports is fine.. just make sure the one way check valve is in the line between the booster and intake.. if fuel vapor gets to the booster diaphragm it can kill it in short order.. With ethanol mixed fuel it's cheap insurance to install a new one.. |
02-28-2017, 06:12 PM | #4 | |
Active Member
On that same note, I always wondered why they changed the location of the A/C compressor on square body trucks to the drivers side. Never did like the hoses routed across the front of the engine.
02-28-2017, 06:48 PM | #5 |
A full manifold vacuum source is correct but it must be a 3/8 tube outlet.
02-28-2017, 07:17 PM | #6 |
*** That's interesting ***
Yep, use a larger (3/8" minimum) nipple. Doesn't matter if it's in the intake or carb. And it doesn't have to be exactly centered in the intake, but it also shouldn't be too far into a runner as you mentioned. I do recommend using a dedicated port. I don't recommend sharing the same source with another vacuum accessory (ie: using a tree/tee/manifold) so you have full vacuum to the booster at all times for safety.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
02-28-2017, 10:37 PM | #7 |
Sound about right. I'm going to pull the trigger and mod the intake and fitting. It's for the LT 5.3... it will be months before I get to test it though.. waiting on Holley to quit changing the pre order ship date!
Thanks for the input Clint
03-01-2017, 12:20 AM | #8 |
The port dumps right into the main intake cavity, atleast it did on my gen 4 5.3.
Are you planning on cutting the quick connect port off of a donor intake and welding it onto your gen 5? Atleast Im not the only one dealing with Holley's ship dates..... |
03-02-2017, 12:37 AM | #9 | |
Not going to drill a new hole, just use the purge valve port. Drill it the same size all the way through, and turn down the vacuum pump brass fitting threads off and press it in there... maybe put a few grooves on it and fill the grooves with rtv. Then include use the brake booster line and fittings... that's the plan atleast. Clint
Tags |
vaccum, vacuum brake booster, vacuum port, vacuum source |
