Old 03-01-2017, 12:03 AM   #1
Robert Bergstrom
Robert Bergstrom's Avatar
ZZ4 radiator shroud
Does anyone know which radiator shroud will work on a 72 with a ZZ4 engine? The stock 350 shroud is just slightly too small in diameter. The big block one does not seem to fit correctly (the diameter is fine).
Vancouver Bob
Robert Bergstrom is offline   Reply With Quote
Old 03-01-2017, 12:17 AM   #2
B. W.
B. W.'s Avatar
Re: ZZ4 radiator shroud
You need an 18" diameter fan to fit the factory shroud. If you are running a serpentine belt you need reverse rotation fan. I used a Derale 17918 fan (steel, 6 blade, reverse rotation, 18") mounted to fan clutch Car Quest part # 215168 to fit 30mm x 1.25 threads on the water pump hub.
B. W. is offline   Reply With Quote
