03-06-2017, 02:21 PM | #1 |
Roadtrip!
Complete 402 BB with th400. 1972
Just pulled from a 72 gmc 1/2 ton burb. Been sitting since 91. The engine does NOT turn over but still has oil in it. 3999290 and date looks like E 15 72. Will sell as 2 options.
Option 1 is complete as seen with the 72 only mounts and alt brackets, power steering set up and trans. smog, etc... $1000 Option 2 is a long block and trans for $400. (no accessories, intake to pan, water pump to trans is it) No shipping and not parting out. Located in northern MN.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
03-06-2017, 04:08 PM | #2 |
Re: Complete 402 BB with th400. 1972
if you decide to part and ship interested in smog setup
03-07-2017, 02:44 PM | #3 |
Roadtrip!
Will keep that in mind. I have one ahead of you on the smog stuff if I decide to split up.
03-07-2017, 09:19 PM | #4 |
I need the air cleaner and spacer, exhaust manifolds with the heat shield and tube.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
03-07-2017, 09:49 PM | #5 |
Do you know if the big block air cleaner is different than a small block?
03-07-2017, 10:12 PM | #6 |
Moderator
They are the same
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
03-07-2017, 10:22 PM | #7 |
03-07-2017, 10:42 PM | #8 |
they use the same spacer, but the tube is different.
03-07-2017, 10:44 PM | #9 |
I have plenty of air cleaners. I need the spacer tube, heat shield and heat pipe.
03-10-2017, 11:46 PM | #10 |
Roadtrip!
Still here, cash talks...
03-16-2017, 10:22 PM | #11 |
Roadtrip!
bump...
03-17-2017, 04:56 PM | #12 |
03-26-2017, 01:30 PM | #13 | |
Roadtrip!
May consider trades for hard to find parts...
03-26-2017, 01:41 PM | #14 |
What are you looking for?
04-05-2017, 09:17 PM | #15 | |
Roadtrip!
$300 plus shipping.
04-05-2017, 09:39 PM | #16 |
Ok, I think I'm in can you give me 24hrs to decide and shipping quote to 98409?
Do you have the bolt with stud on the end where the adjusting bracket connects to the water pump? I never thought about it before but I guess the ex manifolds are included since they have smog holes... I guess 2 spark plug heat shields are missing? |
04-05-2017, 09:46 PM | #17 | |
Roadtrip!
The manifolds are included... I didn't even try any of the tubes. I did soak them for a few days. Pretty much what is pictured and the pump does turn.
04-10-2017, 05:02 PM | #18 | |
Roadtrip!
04-10-2017, 05:32 PM | #19 | |
I will offer $125 shipped for the pump with the attached hoses. Should fit in a large flat rate box. |
04-10-2017, 05:40 PM | #20 |
That's a very good price for the smog parts. The water pump pulleys are different for the smog pump. Might want to see if the buyer wants them.
Dan |
04-10-2017, 05:49 PM | #21 |
That engine in non A/C and has the standard double row water pump pulley that most have, which runs the SMOG pump. The pulley for A/C has a 3rd row pulley on the water pump which is smaller in diameter. The SMOG pump pulley sits out further too with A/C.
04-10-2017, 08:57 PM | #22 |
Roadtrip!
I am going to try to sell together if possible. If they don't sell, I will think on your offer.
04-10-2017, 11:42 PM | #23 |
I will take complete
Posted via Mobile Device |
04-11-2017, 08:22 AM | #24 |
Roadtrip!
Let me see the best way to get it shipped without damage for you.
04-11-2017, 11:03 AM | #25 |
figures.....the engine is gone, just found out my 402 is cracked and I am finally close
