Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 03-17-2017, 09:07 PM   #1
Tim Christian
Tim Christian's Avatar
Tach Dash
I have a factory Tach-Dash not sure what year 73-80 it has the tach harness and a pigtail for the main connection It has a 80 PSI oil pressure gauge. It will need a new lens (Scratched really bad) and a circuit board(separating) I can not get my pictures to upload but I can text them to you Asking $300.00 shipped.
Tim Christian is offline   Reply With Quote
Old 03-18-2017, 11:02 AM   #2
Tim Christian
Re: Tach Dash
Finally got a couple of pictures to post anyone know what is the correct year? Thanks
Old 03-18-2017, 05:23 PM   #3
dooce
Re: Tach Dash
Amps gauge indicates 73-75 I believe. There used to be a good how to for identifying these on the 73-87 websites I think
1976 Chevy 1/2T 2wd SWB
327/Saginaw 4spd 3.73:1
LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071
LFSalleeII@gmail.com
dooce is offline   Reply With Quote
Old 03-18-2017, 05:29 PM   #4
dooce
Re: Tach Dash
Found it.
http://www.73-87.com/7387garage/inte...achometers.htm
Old 03-18-2017, 05:33 PM   #5
gmachinz
Re: Tach Dash
That's an odd cluster...amps indicate 73-74 and the tach with the colorband is 78-79 as is the speedo judging by the blue acccent...so I think it's a put together 73-74 with 77-79 speedo and tach.
gmachinz is offline   Reply With Quote
Old 03-18-2017, 09:03 PM   #6
1968vetL-71
Junior Member
1968vetL-71's Avatar
Re: Tach Dash
yup, and it also has the large "windows" under the speedo and tach which is 77 and later.
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 03-18-2017, 10:43 PM   #7
gmachinz
Re: Tach Dash
Ok...so closer inspection of the pics reveals:
No mechanical oil gauge/line so it's a 1978-up tach housing
Appears to have a 73-75 amp gauge instead of 1976-up volts
Appears to be 1977-79 speedo/tach judging by the accent blue
Appears to have large indicator windows so NOT 2WD
Now, assuming this has a correct tach printed circuit (no production C/K/R trucks that I've seen have both an amp gauge and an electric oil pressure gauge) and all 73-77 mechanical oil gauge I've seen are 80 psi while the electric ones are 60-the only other type of truck I've seen this exact type of cluster in is the big series C60/C70 gas trucks or any version of that chassis-grain trucks, etc. so that's my guess as to the origin of this particular cluster.
It will still work in a regular truck tho-the oil pressure switch would be tuff tho-whoever buys this should look for a 1978-80 C60 series gas engine 366 truck as far as parts store application-may have to research the OEM GM switch part # and then cross reference that.
Old 03-18-2017, 10:55 PM   #8
gmachinz
Re: Tach Dash
I looked through my catalogs and it looks like the correct 80 psi electric oil sending unit for that cluster is Standard PS157. The GM # is 14039612 but doesn't appear to be available anymore. So there ya go-if anybody is interested in that cluster you may wanna take note on that-there aren't gonna be 366 parts readily available in the future-might wanna buy 2 or 3 of them sending units lol
