Old 03-23-2017, 10:03 PM   #1
63ChevC10
63ChevC10's Avatar
1963 fleetside - rear rim width
Ok here goes. I know this has been covered a million times, but I've looked all over the forum and the web and I haven't been able to find a clear answer. Like the subject says, I have a 63 fleetside and it has a stock 12 bolt in it. I'm looking at putting a 15" wheel on the back of it that's 10" wide with a 4" offset. Will it fit without modifying the truck?
Thanks in advance!
Jerry
63ChevC10 is offline   Reply With Quote
Old 03-24-2017, 12:10 AM   #2
Captainfab
60-66 Nut
Re: 1963 fleetside - rear rim width
That depends on what tire you mount on the wheel and whether your truck is stock height or lowered.
Thanks in advance!
Jerry
Old 03-24-2017, 04:23 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
I don't think a 15x10 with 4" backspace wheel will work. But, don't my word for it...make sure by removing one of the rear wheel/tire, jack the rearend housing up to ride height, and take your measurements with a straight edge and ruler.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-24-2017, 06:38 PM   #4
63ChevC10
63ChevC10's Avatar
I appreciate the feedback guys. I meant to mention that the truck is lowered 4" in the back. I didn't include the tire size because I'm not sure what size I'd need. I currently have 235/75R15 on the 8" wheels that are on it so I was looking for the same overall diameter if/when I put the 10" wheels on the back to keep my speedo close to correct. I've been to 2 tire shops and neither have had any luck finding anything that won't make the speedo like 10+ mph off. So it looks like I'm going to drop this idea for now.
Again, thanks for the feedback!
Old 03-24-2017, 09:54 PM   #5
hotrodder
If you are still interested . I have a 65 GMC stepside and from the frame rail to the inside of the rear rim lip is 8". It is lowered with 4 of the leafs of the spring removed. Stock rims.
hotrodder is offline   Reply With Quote
Old 03-24-2017, 10:20 PM   #6
63ChevC10
63ChevC10's Avatar
Thanks for the info man!
