04-09-2017, 12:08 AM | #1 |
Battery drain but on answer in fuse panel
Replaced my optima battery a few months ago thinking it was gone (10 years old). Bought a new Optima. The old one is sitting on the bench and I decided to check it with my meter 2 weeks ago. Shows 14.2. (I had it on the charger when I swapped it out.) It dawned on me that I may have a current drain. Sure enough, went to start the truck yesterday and the new battery was almost dead. Did the fuse panel thing today with the test light hooked up to the negative cable and none of the fuses removed showed a faulty circuit . The exact same thing happened a few years back. None of the fuses removed caused the test light to go out. A friend who is sharp with wiring discovered that it was the aftermarket radio. This fall I had a local stereo shop install a new stereo system. Is it possible that I have the same problem? It just seems odd that after several months the problem is now showing up. I did start the truck periodically over the winter with no issues. I am at the point now where the battery is almost dead after a week and I had recharged it fully with my battery charger. I am hoping that somebody has run into this issue and can point me in the right direction. Thanks in advance.
04-09-2017, 12:17 AM | #2 |
Post Whore
Re: Battery drain but on answer in fuse panel
When you said you did the test light thing what exactly did you do? The stereo would be the first place I would look. I have very little faith in stereo installers to do anything except install the stereo as quickly as possible. They may have cut or pinched a wire in their installation frenzy.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-09-2017, 01:14 AM | #3 |
[QUOTE=HO455;7910344 I have very little faith in stereo installers to do anything except install the stereo as quickly as possible.[/QUOTE]
X2 And they probably used these things. Possibly the WORST invention ever! https://www.lowes.com/pd/Utilitech-2...tors/999956682 GUARANTEED to cause you problems. |
04-09-2017, 01:18 AM | #4 | |
Freaking Junk. |
04-09-2017, 08:28 AM | #5 |
Thanks for the replies.
04-10-2017, 01:52 AM | #6 | |
04-10-2017, 05:53 PM | #7 | |
You're right. Was just commenting on hacked stereo installs, and the general shoddy workmanship you usually find in the neighbourhood of those connectors. On topic, it's possible that the installer ran the power wire for the stereo memory direct to the battery and bypassed the fuse block entirely. Easy enough to see. Could drain a battery over long term storage, and several deep cycles of the battery and it won't hold a charge for long. I'd pull the firewall connector for the harness and see if the draw goes away. Yes - it's in-cab, probably related to the ignition switch harness. No - it's in the engine compartment, likely alternator backfeeding, starter solenoid, or in the harnesses themselves. Seen plenty of voltage leaks through visibly sound insulation. Everything else goes through the fuse block. |
04-10-2017, 08:54 PM | #8 | |
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
