04-10-2017, 11:26 AM | #1 |
Truck I want, advice needed
I want a 64-66 truck just because. I want it for my honey business (beekeeper) so the shop truck patina look. I found this truck and I like it but after reading here I wonder if it is lowered to much to drive. It's 6/8 static. He said the trar was new but it needed new front coils. Here's a link to add. I offered him 5500 but haven't heard back yet. I know I'll have to change the tires and was thinking about wheels too but that might make it worse? Don't want to big of a project truck because of time and the amount driven. Thanks Charlie
https://billings.craigslist.org/cto/6074419536.html |
04-10-2017, 11:53 AM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Truck I want, advice needed
I would run it like it is, however I would definitely look at the welding work done before I shake hands. If there isn't good welds and birds mouth on the frame then I would walk away. Also be ready to put bags on the back, I know those bee houses can be heavy to carry.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-10-2017, 11:59 AM | #3 |
I was wondering about the conversion. So you don't just cut the bed but you shorten the frame too huh? Seems easy enough to do but I get not wanting to hack it together. He said 6 was lowest he would go? If I had to go through the chassis- spindles and springs ect ect. How much would I be looking at? 1500-2500? Thanks Charlie
04-10-2017, 01:50 PM | #4 |
A good inspection is in order. Extent of rust and quality of work done are key. Appears to be a decent truck with a fair amount of effort already into it. If it checks out ok, the seller won't have to dip much (if at all) on his price.
04-10-2017, 01:54 PM | #5 |
Got him to 5500 and going to see tomorrow. Wish me luck that it's not a hack job/mis leading add. Hope it works out, I've wanted one of these forever
04-10-2017, 02:00 PM | #6 |
Yes, a shortbed conversion includes shortening the bed (you can see the two vertical seams on the bedsides where he shortened them) and shortening the frame accordingly. On the rear, you just cut off the extra length, but in front of the rear wheels you need to take out a 12" section from the frame because a shortbed has a shorter wheel base. I would inspect how he did it very closely. Most guys do a staggered cut and then add a fish plate or box the frame for added strength. There are tons of build threads detailing the process.
I'm wondering why it needs new springs. In the ad he says it has CPP springs. I can't imagine how those could go "bad" under normal conditions. Maybe the ad meant only the rear has new springs. If he says it needs new fronts, most likely they are the stock springs with 1.5-2 coils cut out, which is a lot. I figure this since it would have to have drop spindles (2.5") and the rest of the 6" in spring drop. Either way, replacing the springs isn't a big deal. I think a 6/8 drop is plenty driveable but could always be raised up a few inches with new springs if you didn't like it.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
04-10-2017, 02:10 PM | #7 | |
04-10-2017, 02:17 PM | #8 |
Provided the drivetrain is sound and you don't plan on fixing any of the body issues (like the rust in the fenders), you should have enough to do some decent changes within that $10K budget. If you're changing wheels too, those 16" wheels are worth something to give you a little kick back.
04-10-2017, 03:41 PM | #9 |
A 6/8 drop is still very driveable. I have a 5.5/7 on mine and there's still room to go lower when I can afford coilovers. Gotta remember that these trucks sat really tall, even in 2wd form, so it would take a lot of drop to create an undriveable pickup.
That being said, it doesn't look to me to have a 6/8 drop, it looks more like a 4/6 to me. He's got 31" tires and I have 29" tires but it seems that mine is quite a bit lower than that one but it's hard to tell for sure. |
04-10-2017, 03:53 PM | #10 |
Yeah just what it says is all I know but I think you are right about that? I just want it I guess and of course that clouds your judgement lol. There's so many for next to nothing here but usually 3/4 Tom and really worked. I don't mind a weekend fix here or there but that's about it till it snows I guess? But to stay married better to not spend to much lol. Here's my car project so you can tell how carried away I get!
04-10-2017, 04:01 PM | #11 | |
Just what I want! Nice! |
04-10-2017, 08:46 PM | #12 |
I would really like to have that gun rack !!!!!!
04-10-2017, 09:54 PM | #13 |
Is it still legal to drive around with a rifle in a rack? Jeez I remember when there where alot of guns in Windows. Montana's still real gun friendly lol. The racks hard to find? Maybe we can trade if I get it?
04-11-2017, 09:40 AM | #14 |
Thank you very much, I appreciate it. It's been a fun journey with the old girl for sure
