Old 04-11-2017, 12:11 PM   #1
snj8198
snj8198's Avatar
Duramax crate engines
Hey diesel gang,
Has anyone dealt with Gale Banks and their crate motor program? I am doing research for my next truck build and I'm wanting a new turn key diesel package. I also would like to use my existing GM NV4500 if possible so I'd rather not go Cummins.
Thank you.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 04-15-2017, 10:57 AM   #2
v30crewcab
v30crewcab's Avatar
Re: Duramax crate engines
sounds pretty cool. do they have prices listed?
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 04-18-2017, 04:41 PM   #3
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Steve, I haven't used any and I don't know anyone who has either. The last time I looked at the prices of the crate engines it was pretty high. Have you thought about finding a wrecked donor truck to start with?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-20-2017, 10:16 PM   #4
snj8198
snj8198's Avatar
Ya I have been searching and weighing my options between factory new, aftermarket new, and a reasonable mileage salvage. The fact is nothing is going to be reasonably priced for what I'm looking to do. Factory GM crate new gen diesels are about $17k and that's just for a drop in turn key motor without accessory drive kit, ecu, wiring harness, pedal, etc to make it run. Gale Banks kits start at $16k and come with everything ready to run but again this is base price. Finally, finding a totaled newer rolling chassis is tough because the body replacement cost is effective against the drivetrain cost. These totaled rigs get gobbled up at auction by shops who can drop a new cab on and resell the rig.
I don't like the new GM body styles nor the bells and whistles. I want the newer Duramax/Alison in a squarebody 3+3 dually flatbed and I'll add my own goodies and wants around it. I'm budgeting $40-45k and 2 years with the idea of half of the budget in the Duramax/Alison/Atlas alone. My current '71 has become a holding platform of a few goodies that can be used in the new build including running gear, braking system, wiring harness, etc. I'll run my D60/14ff. Money could be saved in stead of the Alison/Atlas if i can use my current NV4500/205 combo but I'm unsure what's available anymore clutch wise to stand up to this kind of torque or if pilot bushing diameters and bellhousing patterns are compatible. I am in homework mode.
I have been penciling out options on a build list of needs and wants. I might as well add another 50% for hidden costs too as many say. Maybe my head is in the clouds.
Steve
Old 04-25-2017, 08:21 PM   #5
Dieselwrencher
I don't think your head is in the clouds. You will just nee to find that great deal at the right time. Keep an eye out for a van with a dmax in it too. You could always get your truck mocked up and then send your engine out for a rebuild. You could do what ever you wanted to it and maybe be under the $16k mark of some other ones. It doesn't take long to eat up money when buying any common rail diesel parts though.
Ryan
Old 06-16-2017, 08:00 AM   #6
70custom20
70custom20's Avatar
Someone correct me if I'm wrong, but isn't the only difference between the GM NV4500 and the ones that came behind the Cummins the input shaft? I thought the input shaft could be changed?
70custom20 is offline   Reply With Quote
Old 06-16-2017, 11:31 AM   #7
DieselSJ
Watch ebay for engines. I just saw a 2016 Dmax engine with ECU and harness go for $3500 (pissed at myself because I set my max bid at $3300). Used ones are getting more plentiful and I think the people that jacked up the prices because they thought these engines would be in high demand for swaps are realizing that Dmax's are complicated and people don't want a complicated diesel. Don't be afraid of a high-mileage engine because all the rebuild parts are readily available and there are a lot of shops with experience now. I'm on the fence between a Dmax vs Cummins for my R30. I'll probably end up with whatever great deal I find when I'm ready to start the project.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 06-18-2017, 09:53 AM   #8
snj8198
snj8198's Avatar
I think there is a little more to it but even so just a main shaft swap with rebuild costs more than just buying the Dodge trans I'm finding.
I appreciate the insight DieselSJ. I am definitely sticking with the diesel build plan but I may have to scrap the use of my NV/205 combo. The Allison will be great, I was just hoping to save a few bucks by running my existing drive train especially since I like to row the gears myself.
Steve
Old 06-18-2017, 04:50 PM   #9
1972RedNeck
1972RedNeck's Avatar
If it is a post '94 GM NV4500, all you need to do is swap to a Cummins input shaft - the main shafts will work with either input. To do this you're looking at about $150.
If it is a pre '94 GM NV4500 with the wider ratio spacing, it would be more involved to make it bolt to a Cummins.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 09-13-2017, 12:04 AM   #10
hedgee76
I was wondering if you contacted Banks on their crate engines? I called today about them and they said that they didnt really have the program going yet like the 2012 article I read. They were coming up with this idea since they were getting the contract to put Duramax engines in the new military vehicles taking the place of the hummers. He said that they were focusing on the new 2017 model engine. He projected engines starting around $19,000.00. Was still working on accessories brackets and stuff. Let me know if you know of anything different.
hedgee76 is offline   Reply With Quote
Old 09-13-2017, 04:37 PM   #11
snj8198
snj8198's Avatar
I've contacted them too hedgee76, no news to report. When project time comes I'll have to make a decision on what route to go. I'm still a year out from starting this project but I was hoping to start data collecting and putting together a budget.
Steve
Old 09-13-2017, 05:22 PM   #12
hedgee76
Big bucks is all this adds up to and a lot of decision making.
Old 09-13-2017, 05:26 PM   #13
DieselSJ
You could buy a complete high-mileage truck and do a wicked build on a Dmax for less money.
