Old 04-14-2017, 11:13 AM   #1
BFoley
BFoley's Avatar
Help Identifying Parts Found In 305e Oil Pan
I have been doing some maintenance on my '66 and found two pieces in my oil pan after I took it off. One appears to be a clip of some nature and the other piece is a partial chunk of something that is made of either hard rubber or plastic. Any idea what either of these things might be? Any help would be greatly appreciated!
http://imgur.com/a/Lb5s1
http://imgur.com/a/78KjS
'66 GMC K25 (305 V6, SM420) aka "Mabel"
Link to project http://67-72chevytrucks.com/vboard/s...d.php?t=698082
All gone - '66 CJ5, '69 C25, '69 C25 Camper Special, '79 C10 Big Ten/Bonanza, '84 K10 Silverado
BFoley is offline   Reply With Quote
Old 04-14-2017, 11:23 AM   #2
PGSigns
PGSigns's Avatar
Re: Help Identifying Parts Found In 305e Oil Pan
Not sure on the rubber part. The wire piece looks like an inner valve spring.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-14-2017, 11:27 AM   #3
BFoley
BFoley's Avatar
Jimmy
That's what I initially thought but it doesn't appear to be a piece of a broken spring. Both ends just have a "sharp" point that appears to be manufactured. Almost looks like some sort of retaining clip. I thought it might be a wristpin circlip, but o can't find any that resemble it online.
Old 04-14-2017, 11:28 AM   #4
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I'd be pulling both valve covers and inspecting all the valve springs, the rubber looks to be from an umbrella seal. Any engine noise?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-14-2017, 12:51 PM   #5
BFoley
BFoley's Avatar
Nothing that stands out. I'll be underneath it today working so I will inspect the bottom-up and then pop off the valve covers to inspect.
Old 04-15-2017, 12:02 AM   #6
kchampagne
kchampagne's Avatar
I'd be willing to bet that is a broken wrist pin clip. Was your engine ever rebuilt? If so they may have used the wrong clips. I had the same thing happen to my 305. Found the broken clips in the pan. Unfortunately for me, when the clip broke, the pin moved back and forth and gouged the cylinder. I had to have a sleeve installed.
kchampagne is offline   Reply With Quote
Old 04-15-2017, 08:38 AM   #7
BFoley
BFoley's Avatar
I don't believe the engine has ever been rebuilt. I guess inneed to figure out exactly what a factory wrist pin looks like. This definitely doesn't look like a portion of a part. It looks like a complete piece with the ends formed like those of a hog ring.
http://imgur.com/IKteMJw
Old 04-15-2017, 10:37 PM   #8
BFoley
BFoley's Avatar
I did some investigating tonight and if I am interpreting things correctly, it looks like the wristpin for a 305e is 1.24". Looking at pics online, it definitely looks like a wristpin clip, but the size is throwing me for a loop. The O.D. of this circlip is around 5/8" and looks like it would go into a recess that was around .595" O.D. x 1/16" wide. I can't think of any other areas in the engine that would use this type of clip...?
Old 04-15-2017, 10:40 PM   #9
BFoley
BFoley's Avatar
I believe I locating source of "plastic/rubber" piece but I am unsure of what the object is. Appears to be a plug of some sorts on front/bottom of block that covered by oil pan.
http://imgur.com/a/5cfnf
Old 04-15-2017, 10:54 PM   #10
Classic v6 GMC's
Classic v6 GMC's's Avatar
Part of the oil pump pressure relief spring?
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 04-15-2017, 11:26 PM   #11
BFoley
BFoley's Avatar
I'll have to look into that tomorrow. It's worth a shot. Thanks!
