Old 04-30-2017, 05:50 PM   #1
az1970k5
az1970k5's Avatar
?Jet performance carburetors
Anyone here have any expirience with their stage 2 quadrajets? They are sulposed to have all the modifications to correct the common quadrajet issues. I have one from National carburetors but not happy with the way it is running, bogs down and I have a hard time starting when hot or when it has sat for more than a couple days, also seems to flood wgen hot. It worked perfect the first couple weeks I had it. It is either this or an edelbrock.
az1970k5 is offline   Reply With Quote
Old 04-30-2017, 05:56 PM   #2
60_project
Re: ?Jet performance carburetors
I don't have experience with JET I do have experience with Quadrajet Power out of Texas. They will build you a carb exactly for your application for about $250 if you send them a core. I have one on my wife's 455 Firebird works great.
60_project is offline   Reply With Quote
Old 05-01-2017, 01:00 AM   #3
robs71k5
K5drive
robs71k5's Avatar
Do you have a spacer under it ? Or a hear shield
robs71k5 is offline   Reply With Quote
Old 05-01-2017, 02:21 AM   #4
60_project
No spacer, just sits on a stock manifold.
Old 05-01-2017, 03:27 AM   #5
az1970k5
az1970k5's Avatar
No spacer but it does have a nice thick heat shield or gasket that it came with. Im pretty sure its flooding because I can smell the fuel. National carbs has good prices but, they just reman their carbs. No mods to improve the more common issues.
Old 05-01-2017, 07:04 AM   #6
72gmguy
72gmguy's Avatar
I used one on a 454 in a 70 chevelle years ago. Was set up perfect from the factory and didn't even make an adjustment and it ran perfectly for 2 years with no problems before I sold the car. I got mine from summit.
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
